A10 redline shifts
TonyD
Waxhaw NC
2024 Mustang GT Performance
New User here, built my Grabber Blue GT Performance Package with Magneride and Active Exhaust. I opted for the A10 because it can shift faster than I can. So I meekly followed the dealer recommended 1000 mile break in, but finally reached that and have noticed when I floor it, the engine briefly lowers the RPMs just before it shifts, meaning letting the A10 shift when it wants and not using paddle. Is this normal, such that I must always use the paddles which forces me to pay attention to the tach?
RJV15
Los Angeles
2022 Honda Civic Si
Thats what the "M" mode is for, it makes the trans shift manually. You can redline and hit the limiter until you hit the paddle.
TonyD
Waxhaw NC
No this happens in regular drive not pulled down to M.
RJV15
Los Angeles
2022 Honda Civic Si
Not quite sure what you mean by this?
TonyD
Waxhaw NC
what I'm saying is, if I floor it in D mode so letting it do as it pleases this A10 does not shift prior to hitting the rev limiter, it blasts right thru that point thus the rev limiter intervenes prior to shifting
TonyD
Waxhaw NC
It's been a minute since I've had an auto trans, last 2 cars were M6s so not sure if this behavior is normal for the Mustang A10 or if I have a problem?
JAM486HP
If you are sure in D, it should not be hitting the rev limiter. Pedal to the floor never had it rev limit, it always shifts perfect
Still getting use to paddles, never had them always a manual. Hit the rev limit a few times with the paddles cause you have to shift so quick. I mainly play in D anyway, the A10 knows what is best
JAM486HP
I know your in D, though have you checked if the paddles are engaged, perhaps it is in M mode and showing in D, an obvious problem
NegativeMultiplier
If you are referring to the shift lights/adjustable rev limiter in the MyMustang settings, that will not actually limit the RPMs. They serve as a point for you to know where to shift depending on what you set it to.
If you mean that the transmission is not shifting when you want it to, there are a few possible reasons for this.
One is that you have not placed the gear selector into M instead of D. At this point the transmission will not shift up unless you click the paddles on upshift.
If you mean on downshift, then yes, there is a gear lockout. This is to protect the engine from over-revving and potentially grenading. The RPMs will drop lower before shifting to a lower gear when it's safe for the engine to do so.
If you have the gear selector in M, and you are just experiencing laggy shifts, try changing drive modes. I have experienced in the automatic versions of this car that the transmission is much livelier in Sport mode and is quicker to shift; I imagine the same applies to track mode and drag mode. Shifts are noticeably slower in slippery mode than normal, presumably to manage traction.
If you:
- Are in M on the gear selector
- In a high-performance drive mode
- Are using the paddle shifters
Then I'm not sure. I doubt you have a transmission problem though.
TonyD
Waxhaw NC
So update: this strange thing happened twice on the interstate on Tuesday, but today while testing 3 times flooring it in D mode(like that's a chore 😂)- the A10 shifted on in it's own perfectly. Hoping it was just a 1 off oddity...
MidLifeManifustang
Toronto
I had the same thing happen to me in the last couple of days on the highway. Drive mode normal, transmission in D, floor it at ~90 km/h (55 mph). Typical 2-lane passing situation.
It kicks down and hard acceleration happens as it revs to redline. Fuel cutoff (or something) occurs, car hesitates and slows for a second, then it shifts.
It doesn’t happen every time, but it’s disconcerting when it does.
Did yours clear up?
TonyD
Waxhaw NC
Yes have not had this again, although there are shifting issues like hanging with a gear far too long, irregular upshifts. Overall this car has electronics issues constantly, if I get a JD Power survey it's gonna be harsh...
You may need to try a reset for a transmission relearn. If one drives like a Grandma and then starts to drive like Mario Andretti things might not work as expected. Shifts will be quicker in Sport mode for sure. This A10 shifts better than years previous.
MidLifeManifustang
Toronto
