Gauge cluster memory issue.
The Deltran battery Tender is OK for AGM. As long as the charge voltage is 1.25v. But newer charts also show the 800 and 750 mah working for AGM.…so go figure…lol. Though there has been some worry about anything lower than a 1.25v charge being too low for the AGM to recognize properly.
But you brought up a good point to look out for in inferior chargers. Ryan’s instruction sheet mentions an AGM, so it must account for it.
Ryan, what’s your Tender’s charge rate?
No idea what the charge rate is. But I'm only 2 hours in and its charged. Solid green light.
The charger has modes for AGM and lithium.
S650 Mustang Gauge cluster memory issue. 20250828_183604
Lol, 4.5 amp...
Well, update completed. I learned something new today. Thanks @Starship Enterprise for your help.
...now i just need to get this damn instrument cluster memory issue solved. Is no one else experiencing this?
Starship Enterprise
MD
2025 Mustang GT Premium
Dusman…yes, sitting locked for 8 hours should reset the battery as well.
Ryan: Wow…4.5 amp! Mine is 1.25 Amps. You condensed 8 hours of charging down to two…lol. I didn’t even know Deltran made a 4.5! Oh well, that’s a time saver.
So you got a software update then? Your instrument cluster issue might be resolved then. You never know what is in an update. If not, it will eventually settle itself down. Electronics sometimes just work their own shit out….lol.
Anyway…was happy to help!
Well I know from wrenching that a fully charged battery should be 12.6v or more. When running you should be above 13.5v.
I googled 12.3v, and it says that is about a 70% charge. 🤷‍♂️
OK, we were a bit rougher then, generally over 12v was OK and over 14v on start up dropping back to 13.5v or so while running. I'll bow to Google wisdom.
Starship Enterprise
MD
I went down the research rabbit hole when I saw Ryan‘s 4.5 amp charger/Tender. Research showed my 1.25 amp was more of a maintainer, and a 3-5 amp is much more recommended for auto use. seems Ryan has a better maintainer than I do…lol.
We all learned a thing here today…good stuff! 🤓
I’m off to buy two 5 amp Tenders!
Paul2020
Australia
2024 Mustang GT Atlas Blue
I had the cluster issue as well. My Ford dealer fixed it. Im usually good at keeping records but think i can find the service invoice to see what they did..
schuvwj
2025 60th Anniversary and 2016 Roush Mustang
If using the Deltran Battery Tender, with the state of your battery, the first few times expect a full red charge light for a solid 14-20 hours! Then it will go into flashing green final charge for about 3-4 hours, then solid green. After you do it a few times, expect a full red light charge for only 6-10 hours, easily a good overnight charge if using daily.
Note the charging times and as you see progressively shorter charging periods, you know you are seeing a healthier battery.
Now for me I’m topped off in 4-8hours…..
When I first put the trickle charger on my wife’s brand new Lincoln, it was full red-light charge for like 48 hours the first few times! Now it tops off in about 6 hours.
I also highly recommend making a reminder card and put it on the driver seat. I did after absent mindedly starting my last Mustang and backing out of the garage only to see in horror it was still connected. 😬
Or do this!
S650 Mustang Gauge cluster memory issue. IMG_2545
