Front inner wheel well issues
infinitemberstang
CA
Dark Horse - Blue Ember - MT
That's what I have in mind:
Possibly these:
https://www.clipsandfasteners.com/product-p/a21780.htm
or these:
https://www.clipsandfasteners.com/GM-Ford-Fascia-Retainer-15mm-Hd-Dia-23mm-Lgth-p/a17103.htm
both would require drilling holes into the existing liner. How do you all feel about that?
All the best,
Hein
DIYvan
liner is not metal - I wouldn’t mind drilling new holes on the fender as long as the body panels are protected from rust/corrosion/paint chips.
I am hoping in the coming year models (2 years) FoMoCo will have a proper fender liner which will fix this issue - until then a DIY which shows community ingenuity will win!
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
I’m thinking a piece of AbS plastic and use a heat gun to mold it to shape. I’ve done things like this before. May attempt it
heinvs
Hood River
Titan, Sprinter, Transit, Saturn
Agree that hand forming ABS would work but is a somewhat complicated shape. We can 3D print these but the best manufacturing would be vacuum forming. We have ability to do that as well.
All the best.
Hein
DIYvan
highvoltage
NorCal to SoCal
All the best.
Hein
DIYvan
Sure but price is gonna be a main point. My guess is the 3D printed ones will cost upwards of $50 a piece based on things I’ve seen. I can get ABS to do both sides for less than $10 and just take time which i have plenty of.
  • Like
Reactions: DCS
TUnica
TUnica
South Hero VT 05486
Me, not clap happy about drilling.
I pop riveted the filler panels I made to the inner fender, I used the appropriate washers for the pop rivet and I'm confident it will hold up. there is plenty of clearance between the inner fender and the chassis, so you wont have to worry about it coming in contact.
heinvs
Hood River
Extended the part 6-8mm around the perimeter which will overlap OEM liner. Modeled up the vacuum forming buck for making both RH and LH parts. Need to CNC it and then form some parts out of ABS or Kydex. These will then be CNC trimmed. Intent is to bond them to the surrounding surfaces of OEM liner with a panel bonding adhesive. Hope that works.
All the best,
Hein
DIYvan
S650 Mustang Front inner wheel well issues Impact_fender_liner_plug_buck
All the best,
Hein
DIYvan
Color me curious
Well finished one side. I used .080 kydex.
Push pins with kydex washers in back of liner. No need to remove the whole liner. Bottom screw was existing. I used a heat gun in areas to form and held with an ove glove until set. Drilled 3 upper holes though liner. This thing is not going to fall off. I'm sure a 3d printed one might be nicer but this will work for me.
6 5/8 x 6
Bend 90° 3 1/8
S650 Mustang Front inner wheel well issues 20240120_201106
S650 Mustang Front inner wheel well issues 20240120_200222
S650 Mustang Front inner wheel well issues 20240120_195916
TUnica
TUnica
South Hero VT 05486
All the best,
Hein
DIYvan
Nice job!
6 5/8 x 6
Bend 90° 3 1/8
Well done!
ListedGuru
Mercury
Do we know what the intended purpose is for this hole (if it has a purpose)? It would be nice for Ford to tell us what exactly the purpose of this hole is . I agree it's a good idea to close it up somehow to prevent rocks and debris from getting in there but what about water getting in there and pooling up? Are we confident that any water that still gets in there after closing up the hole will be able to drain so it's not sitting in there causing rust and rot to the metal?
REV745DH24
Why haven’t they told us yet?
