Forscan
Yes I enabled that (point 3) I think I used the values in the sheet under auto-lock, haven’t tested that though.
Thanks!
I can confirm that, if the changes were applied correctly, it will work. :)
pecco1988
Northern New Jersey
Here is what I have done till now:
- continuous gear display
- walkaway lock with feedback
- auto lock after 45s
if you dont mind me asking. what did u exactly change for those?
bfets
Western Australia
Just wondering. I'm seeing lots of people complaining about the "keep your hands on the steering wheel" warning which goes away if you disable lane keep assist. Problem is the car defaults to this being on so you need to turn it off every time. Can this be defaulted to off with Forscan?
Zeeku22
Utan
S650 gt premium 10 speed
* removed emergency-brake nag
* got rid of seat belt chimes, displays, nagging
* got rid of door open chime, start car chime, startup chime, and other senseless sounds
* forced warning/notice alert sounds to come through 'instrument cluster' instead of sound system (much quieter, less annoying sound, and sound is shorter)
* force clock to 24hrs (didn't "stick" when done through the dash)
* removed front radar, and therefore disabled
** adaptive cruise control
** low speed collision mitigation
** lane assist
(above allows standard cruise control to work)
* changed keyfob panic alarm from one press to two presses, to prevent accidental triggering in pocket
For the forward collision assist you can actually disable it through the abs module, it'll disable collision assistance while still allowing adaptive cruise and normal cruise control to be toggled, although you will have a "collision assist unavailable" warning on the dash. I like it being there as it confirms that The collision assist is off. You can remove the warning All together through the BCM.
Highlighted in blue is the address that should be changed to 1
If there is an issue change that same number back to 5
ydoucare
US
2024 EB Premium
This is probably a shot in the dark, but does anyone know if it's possible to allow custom steering feel setting in the non-Normal drive modes? Sport/Track/Drag/etc have it locked to the drive mode. On the S550 we didn't have this limitation. Nothing in FORscan stood out for this, so probably just wishful thinking, but figured i'd ask.
ydoucare
US
2024 EB Premium
I think a custom profile can do that.
Sadly no, you can only change the steering feel in the custom mode if the base mode is Normal. If you choose any other drive mode as the base then you can't change the steering, it'll be locked to whatever the base mode is.
That's too bad... I saw the setting in there, but I am not using custom modes, so not too familiar with how they are setup.
ydoucare
US
2024 EB Premium
Yeah, i'm not sure why they would impose that limitation. It's a head scratcher.
Linwei
Germany, UK and UAE
S650
Can I ask please what you had to change to enable walkway locking?
I posted in another thread here, but could not get it to work.
I changed the APIM
7D0-09-05
BCM
726-91-01
In the first tab of the excel sheet it also mentions to change BCM 726-97-02, but these lines don't even show up for me. The entries stop at 96.
D/\rK•650
2025 Mustang DarkHorse
Hello would you mind posting the values you changed to get these to work? Maybe a screenshot with the highlighted characters to change? Im new to Forscan and I am wanting to take a crack at it after I learn Forscan a bit. Maybe it would be different i have a darkhoe?
BimmerDriver
RDU, NC
For the forward collision assist you can actually disable it... although you will have a "collision assist unavailable" warning... You can remove the warning All together through the BCM.
That worked great, thanks!
Dark Sprite
UAE
Can one of you who has Forscan please confirm whether it’s possible to disable/enable remote rev function and what setting needs to be changed to allow it?
rugedraw
Miami, FL
This is enabled here in the PCM:
There may be other things that need to be changed in other modules......not sure, but this for sure needs to be enabled.
