FORSCAN - Changing Tire size
goodlettjr
Houston, TX
New to FORScan. Has anyone used FORScan on the 24 mustang yet and if so have you been able to change tire size?
I purchased an OBDII connector for FORScan but haven't used it before or tried to connect it yet. Bought the OBDLinkEX that FORScan recommends through Amazon.
LCDRChemEng
Yulee, FL
2024 BE DH Premium A10
I hooked it up and it would not recognize the car.
Ill have to check to see if there's a software update or plug in...
FroYo
NJ
I have one version that should support but I didn't test it yet (version: FORScanSetup2.3.57.test20230919)
I will share link let me know if it's working
Dave2013M3
El Segundo,Ca
Forscan doesn't support the 2024s right now.
Stang24
Chicago
2024 mustang
It should. I saw on a FB group someone updated to newest version of it and it connected to it
goodlettjr
goodlettjr
Houston, TX
I saw the same post on FB. But also saw on thier site that the 2024 is not supported. I assumed possibly a few things.
1. Not officially supported but will connect to some basic things. (But don't really expect that b/c that's why the do beta releases)
2. They downloaded the beta, but if I remember the post correctly , they mentioned the software version and that wasn't the beta.
I don't have any prior experience with ForSCAN so I am waiting.
goodlettjr
goodlettjr
Houston, TX
Ok, I had a few minutes and my curiosity got the best of me. Version 2.3.57 connects. It reads the BCM module. Will let you edit the tire circumference in mm. I didn't change anything. I haven't bought new tires for my new rims yet.
cdidrr
2024 Mustang
Has anyone had any success yet in officially editing/changing the tire circumference using Forscan?
Dave2013M3
El Segundo,Ca
Dave2013M3
El Segundo,Ca
I'm not sure I understand what you mean by "diameter"?
You only have to change the Forscan if the overall tire diameter is larger or smaller than OEM. If its less than .3" I wouldn't bother.
What @Dave2013M3 said!
As an example the OAD of my OEM Goodyear 265/35/20" all seasons is 27.3 ins.
The OAD of my Nitto 305/35/19" summer tires is 27/4 ins.
No change necessary.
20ducks
Originally South Side Chicago
2024 Mustang GT Premium Convertible Shadow Black
Car came stock with 19" tires. I don't know anything else about them as I had them removed before I took ownership. I didn't keep them. What I put on with aftermarket rims with Goodyear Eagle F1 Asymmetric 265/35X20.
