SameI am using surround mode and it sounds better than stereo to me
Did you change front tweeters or center dash speaker or woofers or every front speaker along with suwoofer. What about sound deadening?Just upgrading the sub alone let the other speakers sound better. I think the OEM sub put out a bad resonance that suppressed the entire stereo system as a whole. all of a sudden the woofers in the door had more presence and after changing the front speaker it really sounds good to me, and I have since lowered the bass in the settings because I was getting too much thump on some songs. Bands like Gorillaz sound really good in the car now.
Wow thanks for the guide, Ill try myself to fix it. Regarding the sound deadening, the reason behind is sometimes the driver side door trim/ dash trim rattles when sound is increased to 12 even with bass set to medium. And I started facing this issue a month after I bought the car.All I did was replace the sub with the Pioneer 10” and the center speaker with a nice 8 ohm replacement. Look up my thread that shows what I used. I just posted it a few weeks ago.
https://www.mustang7g.com/forums/th...ding-the-subwoofer-and-center-speaker.169481/
I didn’t go deep with sound deadening or anything else.
Ok let me try that. I have an update on the rattling issue, it even rattles when sound is of silent exhaust, it only does not rattle when window is open, maybe the wind from window surpasses the rattling noise. If i push hard on the door panel and hold the trim either with my elbow, the noise is reduced or sometimes stops. Its been over a year but it hasnt fixed yetI don’t know if sound deadening like Dynomat would solve a rattle. Sounds more like a loose screw or clip. Personally I’d try to solve the rattle by isolating the rattling panel or trim …and if it’s loose clips, just secure with small tabs of 3M double sided tape. Just enough to lock in the panel, but not so much that the panel would be too difficult to remove if needed.
