2025 9.5 qt oil capacity vs. 2024 10 qt
Jonyxz
San Juan, PR
2019 5.0 401A 10R80
Possibly still takes 10 when fully empty and 9.5 for changes.
first Mustang
2025 60th anniversary GT
Different but related, does anyone know what oil 5.0s come with from the Essex factory?
It seems that would be helpful to know when deciding which oil to use. I am leaning toward the blend, at least until well broken in.
DarkMatterGrey
DarkMatterGrey
Scottsdale AZ
5w-30 semi synthetic possibly with an additive (XL-17).
Grabber1
Washington
i use a Ford Racing FL-820S and 10 quarts.
I use the Motocraft FL820S in my 2009 GT500. I use the FL500S in my 2024 GT. Is Ford Racing recommending the use of the FL820S in the 24 GT?
S650 Mustang 2025 9.5 qt oil capacity vs. 2024 10 qt 20241217_142210
S650 Mustang 2025 9.5 qt oil capacity vs. 2024 10 qt 20241215_120821
SSuperDave
Friendswood TX
It is not recommended, but it is a larger filter and does fit.
S650 Mustang 2025 9.5 qt oil capacity vs. 2024 10 qt 1734715764602-6w
PBBLASTER
2025 GT w/ PP, Transit 150, jeep wrangler, Toyota FJ
I just took delivery of my 25 GT yesterday. The oil is on the lower end of the crosshatch so it looks like they are actually using 9.5 from the factory.
IFFV68
If you fill it to the "full" mark on the stick,,, GTG
I believe the 2024 Mustang Owners Manual say,
10 Quarts including Oil Filter.
I will double check?
220, 221 ... whatever it takes :)
Doesn't really matter. Fill it until it reads full on the dipstick.
S650 Mustang 2025 9.5 qt oil capacity vs. 2024 10 qt 1738857767810-g4
S0696
NC
2025 Mustang Dark Horse Tremec Blue Ember
Thanks for the feedback. I recently took delivery of my 2025 DH and I checked the oil at 140 miles and the level was just above the minimum required level. I thought that was strange as I never had a new car that the oil level was not at maximum indicated. I will monitor it and change it at 1,000 miles.
Ford saving money... a quart of oil on every car adds up... 😆
SSuperDave
Friendswood TX
Its them Canadian Coyote makers, shorting us half a quart to get even!
Ask your dealership why the failed to perform proper PDI.
S0696
NC
I don't even think they did one. They also delivered it with the shipping blocks in the front strut springs. I had to remind them for removal. I picked this car up a few hours a way because they happened to have the exact specifications I wanted. My local dealer is far better than that.
silex
Indiana
I just changed my oil for the first time (dealer did one before this). I had the front wheels on ramps and drained for at least an hour. I replaced the filter as well. I filled to just under 9 quarts and the dipstick didn't register any oil. I decided to dump the rest of the second jug in (10 quarts total). My dipstick now registers right at the top of the fill range or perhaps a hair over. It is hard to read as oil tends to streak along the stick in places). Is there a chance I have overfilled the engine? Should I be concerned seeing as new manual recommends only 9.5?
Do car manuals list "fill"capacity (including filter) to be added for oil change or instead total capacity as if filling brand new totally empty from factory?
