Wheel Spacers!!
MyDarkhorse79
San Antonio
24 Mustang Darkhorse
My rear 1" spacers don't look flush like most of the pics on this thread, I may try 20mmđź‘€
Coachfarbulous
New Jersey
2015 Mustang GT
I've heard that many people try the 1 inch spacers and if they are too much, they just try a different size. That's a $185 mistake if you bought Eibach spacers. What do you do with the old ones? Can they be returned?
Deleted member 17846
Guest
Yeah 20mm = 0.78in
Usually with those the wheel studs will be too long and you will need to either cut or install short wheel studs.
I know for a fact that 20mm does not fit the Performance Pack wheels without cutting or replacing the stock wheel studs.
22MavXLT
East Bend, NC
2022 Mustang, 2024 GMC AT4, 2024 Bronco Raptor (Wife's), 2024 Mustang GT Premium
I have magneride and I'm using 1" spacers with no problem. Run them on my 24 and my 20.
Which wheels are you running? I was thinking of doing 1" spacers on my Daughter's car. She has the Perf Pkg and Magneride.
Stangerous
Space Coast, Florida
Factory staggered set on both cars, both are PP cars with magneride as well
So0_NaSTy
NY
2024 Ford Mustang GT Premium
I managed to put 25mm on all 4 corners on my Mustang. The cars pretty much new so I didn’t need to really sand or wire brush the light oxidation on the hub. I put the spacers on and torqued em, they look a lot better now. Rear is pretty much flush I’d say. The front still isn’t 100% flush, from factory the fronts have a really big gap from the fender, so 1 inch isn’t quite enough, but looks great.
A.alansari
Qatar
Mustang GT 2024 PP
My car magnaride and steeda 1" spacers all around stock wheels
S650 Mustang Wheel Spacers!! IMG_0001
S650 Mustang Wheel Spacers!! IMG_9999
S650 Mustang Wheel Spacers!! IMG_9998
S650 Mustang Wheel Spacers!! IMG_9997
kinelisch
I put 25s in all 4, I love the look and get tons of compliments
What lowering springs do you have? Looks amazing!
kinelisch
I did not cut anything. Bolted right up and smooth as before they were installed.
Just to confirm, the 20mm will work without cutting correct? Thank you
89Trooper
Central Florida
@cosmo73 I'd like to know this, as well. Normally there is enough of a "hole" in the back of the rim for the stud/nut sticking out past 20mm.
8915GT
I purchased 25MM spacers from American racing and would not fit, lugs indented the wheels on the inside so I did not even install them. 2024 GT, with 19"silver aluminum wheels. Probably need 30MM if you do not want to trim your lugs
