Wheel Spacers!!
heymoose
New Jersey
currently Mach E
Yes, mine are 9” all around. I had to grind off a good amount. But it looks great now. Not sure how deep the “wells” are on your 9.5” rims.
Thanks - I’m okay with grinding down the studs just wondering if my offset is different on the 9.5’s and if the 15mm is the correct size.
89Trooper
Central Florida
I did the math a while back. The offset on the 9.5” brings the tires in a bit so they stick out as much as the 9”. Or it’s at least very close. Drape a string over your fender wells with a nut on the end to see the distance they are under the fender. Then you can decide on 15mm all around or 15/20mm. But I think you’ll end up wanting the same all around. Good luck and let us know!
heymoose
New Jersey
currently Mach E
I did the math a while back. The offset on the 9.5” brings the tires in a bit so they stick out as much as the 9”. Or it’s at least very close. Drape a string over your finder wells with a nut on the end to see the distance they are under the fender well. Then you can decide on 15mm all around or 15/20mm. But I think you’ll end up wanting the same all around. Good luck and let us know!
Thanks! Will do
Silverstone
2025 GT 6spd
Those of you running 25mm spacers....you're really not getting any rubbing at all? With hard cornering, big dips and bumps, etc., no rubbing? I guess it's possible, but hard to believe especially in the rear when all these pics of ppl running 1" spacers show the tires proud of the fenders by 5-10 mm.
D/\rK•650
2025 Mustang DarkHorse
I have to agree Silverstone, definitely seems like it would rub. If not it has to be like as close as in the thousands of inch.
