Typewriter Tick/ BBQ tick fact compilation?
FrankAR15
Lexus IS Fsport, Toyota 4Runner, Genesis coupe
Dealer did 1st oil change at 3500 miles. Used semi-synthetic ford oil. So far, no ticking
Hawkeyye
Oregon
2023 Mustang GT premium
@FrankAR15 ...... just changed the oil at 3000 miles on my 2024 Mustang GT. I used Motorcraft FULL synthetic 5W-30 and the Motorcraft oil filter. I had the tech prefill the oil filter with oil to soak the filter's filter media then add some more oil before installing it. I am now a 4000 miles with no "tic". Sadly I do have the R1080 auto transmission whine, so you win some you lose some!
That sucks. The whine is 10x worse than the tic imo. I wont buy another auto until thats fixed. Manual seems to happen less or not at all.
@Hawkeye ..... doesn't happen at all with the manual, at least not for the same reason. It is the straight cut gears for the auto transmission's fluid pump that make the noise. It is a bit annoying at low speeds where there is a wall like in a garage or a drive through and the sound reverberates but I don't hear it above 20 mph and I have a convertible. The boss (aka the wife) says it sounds a bit like a supercharger. I'll take that. A friend has one with the tic and that makes me nuts because it is erratic. LOL.
omagic89
2019 Ecoboost - Owned 2024 GT - On Order
Is this the bbq tick or something else you think?
No tick here, just some wine.....whine. I don't mind it, hasn't got worse. The auto has got better, in fact.
Yep thats it. They all do it to varying degrees. Ive been using a half bottle of Ceratec after my oil changes in my last two Mustangs. It usually goes away immediately.
You will be waiting a looooong time then. The 10R80 has always done it since it was first made 10 years ago so clearly it isn't going to change.
NVERL8
Cincinnati
2019 GT- had the tick, don't remember when it showed up i put a lot of miles on that car
2025 GT PP- no tick so far 2 changes in with motorcraft full syn and motorcraft filter.
RobsCountach
Central VA
2025 GT 6sp
If Ford doesn't know why it happens, then they don't know if it's harmful... common sense.
Doubt it'd be piston slap as that'd quiet down as the engine warms.
Direct Injections engines quite the tick-tick beasts anyway... but odd its intermittent and some say, helped with oil additives.
Ford DO know what the noise is and the TSB clearly says it is not a problem and is a normal feature for the engine. Just because they haven't made the details public doesn't mean they don't know
The problem is people on the internet conflate the typewriter/BBQ tick with injector tick. They are two totally different things.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
Shhhhhh, don't tell anyone. Better to think Ford is just stupid. It's better for the narrative!!! :crackup: :cwl: :like:
All generations of the Coyote have had it to some degree. That goes all the way back to 2011. To date, im not aware of a single failure related to this. If fact, Coyotes seem to have a pretty solid reputation for reliability overall. If this were a real mechanical issue, we would have found out about it a long time ago.
Both my S550 and S650 have/had the tick. Plenty of miles on the S550 without any negative effects.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
Oh I know. But there are still folks who think it's a big mystery like Bigfoot or Amelia Earhart.
