Status
Not open for further replies.
Bybotie
Dallas
2024 GT Premium, PP
A few things I noticed:
Wide body kit (look at the headlights)
Ducktail spoiler
CF Wheels
Carbon Ceramic Brakes
CF Hood with pins
The name might be questionable, but the goods are not.
Epiphany
Global
I like to disassemble things.
I highly doubt the hood is CF or that the rotors are carbon. Cost is exorbitant.
A_Bau3
Wisconsin
All of them
The rotor hat looks black, and I doubt they would go back to crossed drilled. They cracked on the GT350’s and they switched to slotted for 2019-20 models.
Epiphany
Global
I know all about the rotors.
Do you see the holes here?
A_Bau3
Wisconsin
All of them
Do you see holes here?
I do, and they look still like carbon ceramics. Doesn’t mean I’m not wrong, but it’s the most logical spot to shed weight because it’s not going to receive the carbon fiber diet like the GTD did.
Epiphany
Global
So yes, they are drilled when Ford went the other way a few years ago.
Again, carbon rotors are way above pay grade here. Unless Ford developed some new technology that seriously lowered cost you won't see a carbon rotor on less than a GTD. And of course it is a logical spot to shed weight, everyone knows this. Problem is, money.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
What if they were an option? What would it cost?
If it has the Predator engine then this is basically a S650 version of the Shelby GT500. Which im sure will be a a great car, but just dont see it being a hit without out the Shelby Cobra name and badging. And you know the price tag is going to be in the neighborhood of 150k.
If this has a Coyote, then its a stunning disappointment, and will definitely flop.
Epiphany
Global
Ford examined that at least twice now with the previous GT350/GT500 and abandoned it each time - a standard carbon rotor, that is. For one, in order to make it more viable, they'd need volume. As an option, the take rate would likely be very low. I've heard nothing on production numbers but it'll likely be low volume (dealers are already frothing, no doubt). Were it an option it would be silly expensive. I think a FP catalog part would be the better play on the consumer end but they've done a good job of futzing everything up as of late.
The Gump
2015 DIB base GT manual 3.55
That a** tho. I like the duckbill. I just watched StangModes video and that doesn’t sound like a coyote. Hopefully we get a supercharged 7.3 even though I was hoping for a factory twin turbo 5.0
ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
2026 Mustang Dark Horse SC
• 5.2L Predator Engine
• Eaton TVS R2650 Supercharger
• Tremec TR-9070 7-Speed Transmission
Engineers and designers looked at every element of Mustang Dark Horse during the evolution to Dark Horse SC. Engine, gearbox, aerodynamics, cooling, braking, suspension tuning, steering feel, tire compounds – almost nothing was left unchecked to take Dark Horse performance to the next level.
“ To engineer Mustang Dark Horse SC, we tested alongside the Mustang GTD and Mustang GT4 at some of the most challenging tracks in the world, including Sebring and Virginia International Raceway, using those elite Mustangs as benchmarks,” said Arie Groeneveld, Chief Program Engineer for Mustang Dark Horse SC. “The result is Mustang Dark Horse SC benefits from every hard-won lesson we’ve learned at the very top of the performance ladder.”
It starts with the Dark Horse SC supercharged 5.2-liter V8 that’s paired with a seven-speed dual-clutch transmission for fast and precise shifts. Mustang Dark Horse SC mixes straight-line performance with a soundtrack that rival sports car makers have largely abandoned. That sound of a supercharged V8 is a core part of Mustang performance but not this fast horse’s only trick.
Every Mustang Dark Horse SC comes with next-generation MagneRide dampers featuring upgraded hardware and software, as well as revised springs with firmer rates, new stabilizer bars, updated front and rear knuckles, and modified front control arms.
Along with improvements in tire technology, Mustang Dark Horse SC elevates handling capability beyond the Mustang Dark Horse Handling Pack.
A lightweight magnesium strut tower brace is standard, while forged suspension links replace steel components to further reduce weight and improve steering feel. And Ford Racing engineers used learnings from both competition and Mustang GTD development to produce a flatter, more responsive handling character than the 5.0-liter Mustang Dark Horse by adjusting the rear suspension geometry and updating the steering rack, tie rods, and power-steering gear.
An optional Track Pack takes the impressive cornering performance and capability of Dark Horse SC to an even higher level.
A Track Pack-specific MagneRide calibration was built around the Track Pack’s standard carbon-fiber wheels. To handle the vehicle’s increased capability, Ford Racing worked with Michelin to develop custom Pilot Sport Cup 2 R tires. Measuring 305-30R20 in the front and 315-30R20 in the rear, this setup leverages Mustang GTD technology to help deliver near supercar levels of traction.
Variable Traction Control, also developed for Mustang GTD from race experience, allows drivers to dial in the desired amount of traction assistance for dynamic driving situations, with up to 5 levels of assistance in addition to fully deactivated ESC.
Mustan Dark Horse SC is available exclusively with Brembo brakes. Six-piston front calipers and four-piston rears with cast discs are standard and build on the record-setting 60-0 performance of the 5.0-liter Mustang Dark Horse, while the Dark Horse SC with Track Pack adds the Brembo carbon-ceramic brakes from Mustang GTD. Complete with 16.5-inch front discs, the carbon-ceramic brakes are significantly lighter than the cast brakes, and along with the standard carbon-fiber wheels and other enhancements, contribute to the Track Package’s 150-pound weight savings. The carbon-ceramic brakes significantly improve thermal management relative to Mustang Dark Horse, contributing to improved on-track endurance and increased driver confidence.
Track endurance was a major goal for Mustang Dark Horse SC, as the design team worked to manage cooling and aerodynamic function with iconic Mustang form. The new front fascia features revised brake cooling, while a new aluminum hood that includes standard hood pins and a large vent improves powertrain cooling and helps manage front end aerodynamics. When the hood vent’s rain tray is removed, it creates 2.5 times the downforce of the standard Mustang Dark Horse hood vent, while the open area is 5 times greater.
In back, a revised rear diffuser contributes to improved rear axle cooling, along with a large belly pan that extends from the splitter to behind the front wheels to manage aerodynamics and brake cooling. The Track Pack makes even broader aerodynamic changes, replacing the rear decklid with a ducktail-style design for improved downforce. The new rear decklid is the base for an updated carbon-fiber wing with exposed carbon endplates and lightweight carbon stanchions – the decklid itself improves the rear wing’s efficiency by around 10 percent, eliminating the need for a larger wing, or one with a higher angle of attack, that would obscure rear visibility.
The new decklid had such a dramatic impact on Dark Horse SC that the Mustang GTD team adopted a version of the duckbill design during a joint development trip. In total, Mustang Dark Horse SC with Track Pack produces 620 pounds of rear downforce at 180 miles per hour.
Function First Design with Vibrant Options
The Dark Horse SC cockpit adopts the Mustang GTD’s leather-wrapped flat-bottom steering wheel, featuring a 12 o’clock strip and performance controls, surrounded by Alcantara and carbon-fiber accents. Optional Recaro leather and Dinamica sport seats are included in the Track Pack, which offers Space Gray or Teal accents and replaces the rear seats with a storage shelf.
Personalization options include a Carbon Exterior Package for the fascias and mirrors to complement the standard carbon-fiber interior finishes and three different brake caliper colors, while Dark Horse SC Track Pack customers can option into a Teal Accent Package that adds vibrant teal caliper brakes, badging, and seat belts. Owners can further customize the exterior with painted graphics, while the cabin is available with five different seat belt colors.
For 2026, the Dark Horse SC family is topped with limited-run Track Pack Special Editions combining the Track and Carbon packages with a black-painted roof, Race Red Brembo calipers, unique graphics, and GTD-derived 3D-printed titanium accents. Available exclusively in Shadow Black or Oxford White, Track Pack Special Edition also features unique Solar Red accents on the Recaro seats.
Mustang Dark Horse SC will be available to order in spring 2026 with deliveries in the summer.
Photos shown have both the Track Pack Special Edition and Carbon Packages.
5.4dreams
CA
11 gt500
If ccb are an option on the zo6 and standard on eray why can't ford do the same? This is assuming this will be the dame price range as the eray.
Status
