Speed bump and loud clunk
magentabronze
austin
2025 s650, active exhaust, molten magenta
I hit one of those big speed bumps doing 25mph and heard a loud clunk from front end. I don’t see any damage in shocks, struts, sway bar etc, but not an mechanic, and car drives fine. Yall think I’m good?
Could have bottomed out... I had the same thing happen the other day, though it was overnight road construction that left a bad bump on my normal route to work. Loud clunk but no damage apparent and everything seems fine. I was worried it could have damaged a wheel, I have 20", so low profile tires. I would say if you feel confident enough to look things over and all appears well, you are probably fine. If you are worried, you could have a shop check it.
magentabronze
magentabronze
austin
Thanks for replying Sofa King and sharing your story, glad everything seems fine! Yah the speed limit was 25mph and had like 5 big humps, but one of hump's the car did not like. I will tell the techs at ford when I take it in for that bcm recall in a couple weeks. I asked AI, and it said only take the humps at 5-10 mph lol.
I have a road nearby where they have some big speedbumps... anything under 25 (speed limit 25) and it is smooth and no bother... anything over 25 and it is a bucking bronco!
Alan Applegate
Roswell, NM
Obviously, the shorter the tire aspect ratio, the harder the 'thump'. That's one advantage of longer aspect ratios.
SilverStang_25
2025 mustang gt premium
I noticed the same thing the other day, and had my friend go over the bump while I watched the underside of the car. Saw a weird bolt sitting lower than the rest of the car from the driver side just behind the cat. Im positive that’s what made the clunk at least for me. I was wondering if you see the same thing under your car? I looked up underside pictures of the s650 and they all seem to have this bolt, not sure if mine is abnormally long or out of place though.
S650 Mustang Speed bump and loud clunk IMG_8290
S650 Mustang Speed bump and loud clunk IMG_8291
D/\rK•650
2025 Mustang DarkHorse
That looks like a exhaust clamp bolt. Maybe it can be repositioned a bit? Then it wouldn't stick out to much? Not sure if their all like that though. I mean if it's an issue.
SilverStang_25
Yeah, I was planning on just asking ford on Monday to see if they could just rotate the clamp. I honestly just wanted to know if a lot of others looked like this or mine was just done weird 🤷‍♂️. If they all are done like this it’s a pretty weird design choice. Does yours look like this underneath?
Starship Enterprise
MD
2025 Mustang GT Premium
my car made a loud clunk just today coming from the area of the rear driver wheel well. I was on a smooth road, no bumps, steady speed, didn't run over anything, nothing in trunk. 🤔
Suspension hitting the bump stops is a fairly harsh experience. Normally it doesn't cause damage.
