Side Bottom Air Deflectors/Strikers
Dena
Phoenix AZ
What really gets me is why the factory doesn't put them in...after all the rear "strakes" on there on the rear? Leaving it up to the PDI folks is simply asking for trouble. Then again...leaving them off, probably isn't the end of the world.
The wheels in transport often sit on rails with sides to keep them from moving much to the side. The ground clearance is only about 4 inches with them on so it's possible for them to get damaged in transport. It's safer just to leave them off so they don't get damaged before you see the car.
Transport devices are designed to make life easy for the hauler but not so much for the car designer.
MJS54
Virginia Beach, VA
'24 Corvette Cpe, '18 Lexus ES 350, '23 Bronco Spt
Dena, well then I guess it’s up to the owners to inform the PDI guys to please install the “strakes” while they have it up on the lift doing the underside inspection for any leaks, etc,. Otherwise it seems there will be lots of DHs running around without their front “strakes.”
MJS54
Virginia Beach, VA
By the way...on my DH the clearance from ground to strakes. About 2 3/4", yikes
BTW, did the PDI techs at the dealership install your “strakes” or did you do it yourself when you got home?
Pyroguy
Wisconsin
Waiting
Installed by dealer. PDI. They are required to.
S650 Mustang Side Bottom Air Deflectors/Strikers IMG_0372
Mastermind46
Denver
Mine were not installed... Also had over 50 miles on it. The instructions were printed opposite of paper orientation so the bottom was cut off and there is a lot of blank paper to the right.
S650 Mustang Side Bottom Air Deflectors/Strikers PXL_20231030_005008980.MP
RiksDH
New Jersey
2024 Dark Horse, 2023 Cadillac Escalade Sport.
Picked up my GT with performance pack and they also were not installed. Here’s a pic, cut the wheel hard left or right, laid on the ground and took about 10 minutes per side.
Thanks for the picture. You didn’t lift it? Were able to put em on by cutting wheel all the way? Enough room to maneuver in there?
Coyote2015
Saint John NB, Canada
2024 DH Premium in Blue Ember Metallic. Previously owned 2015 GT
Picked up my Dark Horse a few days ago and also noticed that the Bottom Air Deflectors and the wheel locks were still in their original bags in the trunk. I installed the wheel locks and dealer said they would install the deflectors. My question is what benefit do they do? With them sitting low under the car I fear they will scrap as I daily drive this car. If I am not tracking the car, do I need to have them installed or do they perform a function that I really need?
Stangerous
Space Coast, Florida
Their job is to deflect air from under the car. The area that mounts to the car is hard plastic but the deflectors themselves are rubber and will “fold or bend” if they come into contact with anything.
FrankAR15
Lexus IS Fsport, Toyota 4Runner, Genesis coupe
Mine were left in the trunk as well. Where do they deflect the air to? Can anyone post more pics?
38.9967° N, -84.6310° W
According to STEEDA.
These under body strakes, factory equipment on GT Performance Packs and Dark Horse models, help generate more downforce and improve aerodynamics, by channeling air out of the sides of your cars underbody, creating a lower pressure area in the rear helping aid downforce.
Engineered by Ford to improve the S650's performance on the track, these underbody strakes redirect the air flowing underneath your car and generate more downforce for better handling when racing. This upgrade is the perfect way to get improved performance at the track. Made from a tough rubberized material these strakes are resistant to underbody impact and will simply flex and return to position afterwards. See the video for more information.
I understand the principle, not sure if enough "channeling" will generate sufficient benefits. Again, at road course speeds, they just might do some good.
They send toward the unofficial inner wheel well aero ports…
