Seat position
Gunnar2015
Gunnar2015
2026 Mustang GT Premium
That’s a good point, @Gunnar2015 why don’t you want to use the easy entry/exit?
I'm only 5'2" so the seat us closer then normal. It's not that I don't want to use the easy entry/exit but it was suggested but even when I get out of the car when I use it again it's back to my driving position (#1). Could the easy entry/exit turned itself back on? I'll have to check
The easy entry/exit will move the seat forward each time you start the car, and back each time you shut it off. If its not doing that, then its either switched off or not functioning properly.
I agree with others. The easy entry/exit feature seems like the most logical solution to your issue. I don't quite understand why you shut it off as you said earlier. Maybe im missing something.
24GTBadlands
IL
24 Badlands v6, 24 S650 with PP GT
My 2018 ford edge when I had it, I had the fob set for seat position 1, so when I walked up to it, it would be ready. I never tried the easy exit, because I am 6' tall and I didnt want to wear out the motors (or something silly like that). but after my wife drove it, I would be able to walk up to it, and everything was back where it should be after I hit the unlock button.
Maybe the fobs were programmed before you got the car. Maybe someone at the dealer was showing a demonstration or tinkering around and programmed them.. you might need both fobs to clear them out, or grab the other fob and see if the same thing happens as the main fob?
My Bronco doesnt have memory seats n stuff :(
However nobody touches my 24 GT so I havent had to play with them.
Gunnar2015
Gunnar2015
I was making it more complicated than it had to be. I turned the exit/entry back on and when I get out of the cat the seat moves back and when I get back in the car, as long as I don't start the car until I'm in, when I start the car it moves to my preferred driving position.
Thank you to everyone who helped/made suggestions. I would have never gotten this kind of help on FB. You guys rock.
Gunnar2015
Gunnar2015
I have to learn things the hard way 😆
Aki
West Palm Beach, Fl
2026 Dark Horse 6sp
This is why forums will never be surpassed by other forms of social media; people who not only offer useful advice but also people who receive and successfully apply it, and post back with results.
Brilliant.
