shogun32
Northern VA
2019 GT+PP, SS+1LE, 2020 F150
I just hope they don't do what they are doing with the 2 door F150.
nobody buys one of those to begin with except as the cheapest possible option - for run-around duty for contractors and parts-supply distribution. Trucks are just tall luxury cars now with price tag to match. You're lucky the 2-door comes in more than one color: white, and has even a FM radio in it. (ed. yes, I'm overstating it a tad)
LSchicago
Illinois
www.LEDandSafety.com
2018 Mustang GT/A 301A 5.0
Not really accurate. Many people buy the 2 door RCSB F150 as an alternative to the Mustang when they need to haul things or tow. It is sad that the options are severely limited. Most people just add upscale interiors and trim to the XLT's themselves.
Stonehauler
Delaware
F350, 550i
ohhh yeay. Lol my memory...
I spent time benchmarking E46 vs LS and I cant recall exactly when the LS w rear section cut out showed up (DEWlite?). Ford leaned on us hard to get the LS to compare to a BMW. You can change tire construction, but suspension geometry and bushings are still key.
Rode along some on X5 testing in 1998. 130 mph yaw damping tests with 1/4 turn violent steering inputs on 5 lane wide oval. Before hans devices... Funny, 20 yrs later have an X5M as a daily. Wish Ford would grab a new X6M and use it as benchmark for a TURBO V6/V8 MachE style extended 4 door MachGTX.(yeay even heavier, lol)
Yes Id pay $110k for it.
I already offered X5M use at COTA to a Ford friend, but he says not yet and they sounded busy at Ford and Im assuming also at Rivian.
I test drove a Lincoln LS in 2003 after my Thunderbird was rear ended at a stoplight by a truck. It was a very sunny 78 degrees and the air conditioning unit could not keep that car cool.
Sorry, but if you live in greater Chicagoland, you need both good heat and good AC. I ended up with a Lexus GS430, which was a great car.
traxiii
Mustang is my middle name
Nor Cal
'22 Mach1 Premium HP & 2001 F150 4x4 Prerunner
No doubt the 2-door will still be there, along all the other cars bearing the name Mustang. I guess my humble point of view is that if everything is a Mustang then a Mustang is nothing. Impossible to be all things to all people and still be special in any way. Appears Ford is exploiting the Mustang marque (theirs to exploit) to the detriment of the car's traditional significance (Mustang SUV, 4-door Mustang, Mustang wagon). Trending toward any Ford that is not a truck being a Mustang.
Go look at the ford.com website and you'll see Mustang and Bronco are now nameplates, sort of like Mercury and Lincoln but without a corresponding "Ford" version. It would not surprise me to see 3 or 4 Mustang and 3 or 4 Bronco nameplate vehicles each.
I suppose if they ever built a 4 door "Mustang" that had room like the Taurus, I'd think about buying it, it it had a V8.
jake_zx2
Kona Blue 2018 GT
Personally, I’m not as opposed to a 4 door Mustang as I am to the Mach-E because it’s much easier to make a sedan sporty and performance oriented than a damn crossover. But it at least shows that Ford is looking to split “Mustang” into its own brand and create a diverse portfolio out of it. But I’m still not a huge fan. I’d still much rather have the Mustang be it’s own standalone model based on a performance architecture designed to span an assortment of models the way that GM did with the alpha platform. I think it could present an excellent opportunity for Ford to bring some competitive sedans to the market and revitalize the Lincoln brand as a serious luxury competitor rather than just a bunch of rebranded Fords
I still don’t understand why Ford refuses to bring the Falcon name back to America. It’s not like the Falcon was ever regarded as a bad car, and the Australian Falcons were awesome
S650 Mustang Rumor: S650 Mustang 4-Door Sedan Will Debut in 2022 with 3 Engine Options 746A489C-A9BF-43B5-AF72-6FE18875FF5C
IceGamer
BMW G20 330d xdrive
If they go for the brand and it looks like they will, what platform are they using for the S650?
Thanks to @amk91 I thought it would be common “knowledge” that the S650 would be built on the current platform, though heavily modified… Unless these modifications are indeed comprehensive they would have to build “Mustangs” on at least 3 platforms… Sounds a bit much… Then again we have the Mach E and the Mach 1 that couldn't be any different…
I like new rumors about the S650 and I’m desperate to see the first mule but the latest “news” don’t really fit into the picture we were painting :D
I thought we would get some optical refreshments, a coyote hybrid and AWD (both optional) and maybe some updates interior-wise…
Now it looks like we get a V4 hybrid, V6 hybrid, manual Coyote, no V8 in Europe, some 4 door car(s) and maybe everything is built on different platforms. Oh and btw a former GM designer (15-20) might make the Mustang interior look like a ’21 Chevrolet Tahoe (https://images.cars.com/cldstatic/w...--dashboard--front-row--interior-22.jpg?w=750) or a ‘21 GMC Yukon (https://s3-prod.autonews.com/s3fs-public/6YUKONINTERIOR-MAIN_i.jpg) … I would honestly rather stick with the current or have any other interior rather than that cr@p.
We’ll see what the future holds…
cizzie000
NY
18 Ford Escape
a four-door mustang with an EcoBoost motor sounds weird lol, it seems like mustang is taking the same leap as Genisis in becoming a brand/manufacturer of its own. If they do make a mustang sedan they should definitely call it something else.
Stonehauler
Delaware
F350, 550i
CLIP
It depends on how "upscale" they want to keep the mustang. It's not a bad interior, especially compared to the Camaro and the Charger/Challenger.
Elp_jc
El Paso, TX
2019 Bullitt K7979, MR, Nav, B&O, Cover
All I know is the 'Mach E' is the polar opposite of a 'true' Mustang in every way, especially a manual one, so basically any imaginable configuration would fit between those 2 now :).
IceGamer
BMW G20 330d xdrive
That's true, the interior is not bad but that's about it. In addition, I think it is outdated and could definitely need an update.
I don’t expect BMW or Mercedes-like quality and features but some things should be optional, like a hud or a 360 camera. In Europe it’s at least a 60.000$ car and I would expect a certain amount comfort…
There is already a section for “what I wish for the S650” but a new steering wheel and a complete overhaul of the center console would be much appreciated. Just don’t make it one large touchscreen ;)
Stonehauler
Delaware
F350, 550i
Personally, I prefer buttons, but I know some want touchscreens. That said...
I personally find that there are times I really want to turn off my display screen in my BMW, and my F350 (and I can in my F350), as the light can be distracting in certain conditions. I don't even want to speculate how bad it might be with something the size of an iPad or larger sitting in the middle of the dash. That and I can put my hand down to a start point (like the temp control) and then move my hands to the proper button, all without having to take my eyes off the road. It's much harder to do that with a touch screen. However, touch screens are lighter and more more configurable than physical buttons, so they should make the car cheaper and save weight as compared to traditional controls. Plus they can be updated and new features added or activated.
As for a HUD, does Ford even have one? Yes, I have had HUDs and I really like them. In fact, any car that I get that has one available for it, it becomes a must have option. That said, if the model want doesn't have it as an option, I am not going to go to a different model/brand to get one.
The Rooster
Ontario
2017 GT350, 2020 Explorer ST, 2021 Lariat Sport, 1987 GT, Jeep TJ on 35's
They already made a 4 door (actually 5 with the hatch) mustang. It’s the Mach E. And it’s an SUV.
Real mustang is a 2 door 2+2.
no real market for a 4 door mustang sedan.
I hate to say it but theres probably more of a market for a 4-door than the 2-door. Mustang owners now mainly consist of enthusiasts. 4-doors will make it an option for daily driven family cars. All-wheel drive will make it 4-seasons, mustang attitude will make it desirable.
it'll probably outsell the coupe 10-1.
Caballus
Europe
GT350
Just looked at the site. Mustang and Bronco didn't appear to be presented as subsidiaries, like Mercury and Lincoln. Just appear to be links to two of their best sellers (Mustang and Bronco).
No doubt many people will by a V8 Taurus with a pony emblem, which is what it would actually be.
