RaceRedder
- Joined
- Feb 1, 2024
- Threads
- 29
- Messages
- 612
- Reaction score
- 382
- Location
- Houston, TX
- Vehicle(s)
- Dark Horse HP
That guy is drunk.You forgot this thread then,must be getting old
Yes! And yes! Thanks. Hopefully they remove the other one.You forgot this thread then,must be getting old
Where’s the boat? I see the car and the cart and a float, saw a truck so assume a boat as well.Yes! And yes! Thanks. Hopefully they remove the other one.
Anyways ...
She got a bath today:
Also a couple of things that are on the way:
Steeda full-length jacking rails
Billetworkz brushed titanium shift knob
Pics after installs.
LOL! Observant.Where’s the boat? I see the car and the cart and a float, saw a truck so assume a boat as well.![]()
Well that sucks. Weather this year has not been good, all over.LOL! Observant.
There are two SXS ('23 Honda Talon 1000R2/FLV and 2021 Honda Pioneer 1000/5 Deluxe). Wife's golf cart too.
We live on a lake. We had a '21 South Bay pontoon with a 150 Yamaha on it, but a tornado/windstorm capsized it last fall. Totalled it. Destroyed all my roll in dock, too. Not ready to buy a new one yet, but I'm sure we eventually will.
Looking good!Yes! And yes! Thanks. Hopefully they remove the other one.
Anyways ...
You bet. Not sure if you are ceramic coated or not, but if you go that route, the effect of using a leaf blower will be just as significant.ROADPILOT
Took your advice on drying my car with a leaf blower last night. Worked great. Thanks,
This is fantastic, thank you!You bet. Not sure if you are ceramic coated or not, but if you go that route, the effect of using a leaf blower will be just as significant.
You might want to check out this company and see if they offer a short nozzle for your model - makes it much easier and safer.
STUBBY™ Car Drying Nozzles for Electric Leaf Blowers — Stubby Nozzle Co. (stubbynozzles.com)
The sphere is the best look imo. Great choice!Added the Billetworkz TITANIUM - BRUSHED - FORD MUSTANG AUTO (2015-24) shift knob and auto adapter lockout system. I got the sphere with the black adapter. Despite being named 'Titanium', it's actually made of 6061 aluminum.
One thing I like about this design is you don't push the entire shift knob down to go into reverse - you just push the collar below it down.
If you happen to get one of these, pay attention when installing it. It's pretty easy, but in the YouTube video they made, they don't mention that, if you push it TOO far down on the shifter before tightening the set screws, it will engage the lockout enough to where your car thinks you're "pushing the button down" (on the OEM shifter), even when you're not touching it. If you do that, when you shut the car down, it will start making all kinds of bells and noise, indicating that the car is not in park (but NO message on the screen to tell you that!). All I did was loosen up the set screws, lift it just a MM or two, then tighten the set screws again. Easy peasy.
Also, removing the trim piece (with the PRNDM markings) is easy - pull up on the FRONT, as there are two clips up there. Once the front is clear, the rear tabs slip out of the slots. So don't try to take the rear out first or you will break them.
The trim piece underneath that (that the boot is connected to) is more tricky. There are FIVE clips on it: Two in front, two on the sides towards the rear, and one on the back edge by itself. BE CAREFUL with the two rear and especially that last one. Start with pulling the front of that trim piece up (use a plastic trim tool), and as soon as you get the fronts loose, do NOT be tempted to just rock the trim piece back 90 degrees -- you will get the two rear/side pieces to come, but you'll break the console where that last clip is on the back edge. Ask me how I know! It's not crucial, as you really only need the four others to keep it secure, but if you don't want to break it, lift the trim piece straight UP (instead of rocking it backwards) and use the trim tool -- those back three clips will come out.
I really like the way it looks and operates. Here a a few pics from the install.
In the second pic, I circled the plastic tab that will break if you don't lift UP (instead of rocking it back) when removing the lower trim piece.
