Normal or Premium Gas
What gas?
  • Total voters
    113
Gogoggansgo
Midwest
2015 mustang GT
If you can’t afford 91/93 octane then don’t have the car that’s my opinion don’t be cheap. The dark horse requires premium anyways
Adeel3466
Adeel3466
Northern Virginia
instagram.com
2024 Mustang GT Premium NP/PP
My original assumption was that it required premium but then heard some people putting in regular gas and decided to look into it but from everyone’s replies I will stick to my original assumption
as far as i have seen, only one person has claimed that Ford says the Dark Horse requires premium. it doesn't, and Ford has never claimed it does. the only similar thing is the disclaimed that horsepower and torque ratings are done by an SAE standard that requires 93 octane.
It's not a matter of affording it or not, it's a matter of principle. Gas is insanely overpriced where i live. If Ford says the GT can run on regular, I'll run it on regular instead of gleefully accepting to get raped by the oil industry.
When you rebalance your portfolio give a 5% allocation to XOM, Exxon or your choice of oil industry major.
buy 93 … profit!
marcekb
Like many vehicles I've owned, I accepted the cost of fuel when I bought the car. 93 is all I use in my Mustang. But I'd rather people be able to enjoy the car than have to pay the cost of 93 if they want to pocket the savings. Around my area, it's been $1.25 - 1.75 more per gallon, although I only go to Costco where it costs the same as 89 at Shell.
OppoLock
RWD Addict
FL
2015 GT, 2020 GT350
If you can’t afford premium go buy a Prius.
I’ve always wanted to say that! :cwl: :crackup:
Seriously, this is around the 100th thread on gas octane and every single one of them is the same. Ford‘s performance and fuel economy numbers are based on premium. Therefore that’s what’s “recommended”. But, as been said before, regular is exceptable. So using regular will not harm the engine but why buy a car like this and then water it down by not using what Ford recommends? I only use 93 Top Tier, but you do whatever is best for you.
these threads are only satisfying when someone posts up some wives' tale mumbo jumbo about octane rating correlating to quality of gas or whatever, giving someone else the opportunity to correct them
otherwise the topic in question is as straightforward as coloring inside the lines of a kids book: use recommended to get full performance and economy, can use minimum if there's a minimum, typically at a penalty that washes out the savings /thread
Jivor
'24 Mustang GT
Is there any long term negative effects from using 87 octane? For a GT with active exhaust, the extra 6 hp should make up the 2% loss in HP. So precluding any persisting damage to the engine, 87 octane should work just fine, yes?
yes yes yes…. The 87 octane can not handle the compression. It ignites BEFORE the piston hits TDC on compression…we call this “hammering the bearings “
The premature ignition is pushing the piston down BEFORE top of the stoke…
87… 93 for that matter is hard on your rod bearings.
E85 ASAP.. for safety longevity
erocker
Milwaukee, WI.
I use premium from Mobil... It's my only choice besides BP. I do go to the newer Mobil station a little further away that is newer with newer tanks in the ground. Top-tier fuel does work well for keeping valves clean(er).
S650 Mustang Normal or Premium Gas premium dude
dollybud
Trenton, Ontario,Canada
Make it 101. Sunoco use to have 102. Now their highest is 94.
dollybud
Petro-Canada has 94 Octan. Price per litre is pretty high. If you can’t afford the best fuel for your stang , then personaly Dont by one.
Interstellar
Dallas
C6 Z06
Hate this logic. No different than saying "if you can't afford a GT500, don't buy a Mustang"
SoggyBottomBoy
US
N/A
Will we really even notice it in daily driving? (My daily driving my involve some pedal to the metal lol) The price difference in fuel makes it hard to want to get premium if its not noticeable.
jamespmoran
Bloomer, WI
Anyone ever use E88? The gas door shows it can handle E0-E15. So I’m curious is going to E-88 (which is 15% ethanol) will harm the engine. Some days you just want to save that $1 per gallon….
I think you might be mid-reading the pump—E-88 is 88% Ethanol. When I drag raced a fox body with a 408, we ran dyno tests with 106 octane racing fuel, and E-85. Made more HP on the E-85, but the constant maintenance on the ethanol wasn’t worth it. On a street vehicle that is not set up for E-85 it will destroy the fuel lines.
without opening the can of worms…..
I try to find a Top tier station and then decide upon octane. It will run on 87 without destroying itself (says so right there in the manual), it’s computer controlled for a reason.
for best performance use min of 91 but a tank or two here and there ain’t gonna hurt anything. I’d be more worried about getting a tank of water than the daily driving impacts of 87 vs 91.
