HOLES IN FRONT FENDERLINER
  • Thread starter Deleted member 64338
  • Start date
  • Watchers 24
zpduff
Recent 2025's appear like below. One part number is PR3Z16103 (and PR3Z16102) for the entire fender liner with MANY revisions.
That's what mine looks like, built in April. The rule still applies, don't buy first model year of anything. Honestly good on Ford for addressing it. I didn't think they would. This forum was probably a significant influence on that.
glenng6
Easton, PA
Recently while browsing on another S650 forum, I came across a post describing what would appear to be a "design flaw" on at least the 2024 S560s. The post described and pictured "holes" in the fender liners ( both sides) directly behind the front wheels. The post went on to show the actual debris ( gravel, dirt, etc.) which had collected within the cavity in the area of the rocker panels. Of course, I felt compelled to examine my 2024 and sure enough there were two 2" X 2" holes in the liners that almost appeared as if they had been "cut" at the factory. Without remedy, there is little doubt that these would end being corrosion magnets.
I have set up an appointment with my Ford dealer for them to start a file on the issue in order to see exactly what Ford will do. The problem has existed with the S650s for so long that there are already companies out there selling fixes ( see DIYVAN.COM for an example). It would be advisable to inspect your '24 and probably '25 S650 to take preventative action. Not too difficult, simply get down and look behind the wheels. Stevie Wonder could see them. I intend to follow up after the dealer inspection for further guidance.
MORIDER,
As has been mentioned, there are a lot of posts about this issue. In the meantime, you can try what I did. In the following post, there is an explanation and pics of what I did. I am sure it won't be permanent, but it is quick, easy, and dirt cheap. Since almost all Mustang tires fill the wheel wells quite well, it is hardly noticeable. I added the tape on May 7, and it still looks like I installed it yesterday.
<https://www.mustang7g.com/forums/threads/front-fender-line-holes-gone.167783/post-3370630>
Good luck. Glenn
I came across a guy in Germany that sells some pretty nice looking fender liner covers that bolt on. Anyone have these or can vouch for them?
Billycar11
yes i got them a few months ago here are my pic
on DH HP car
Got Mine from him and fits perfect no messy glue 5 mins per side and your done fits perfect just follow the video he posted 1 bolt holds it all in and has a slot for the fender liner.
got them from [email protected]
anther user on his
I bought these and installed. I was hesitant to mess with glue/jb-weld stuff and really glad I didn't go with the other solution.
Install is super simple on the garage floor, 10 minutes max. They stay in place, look good and mod is 100% reversible what I personally like a lot. Purchasing process was also top-notch. Recommend!
They are dirty on photos because they work! Photos are made couple of weeks after install.
on DH HP car
anther user on his
Awesome. I ordered them last night. Its cheaper than that other version and I like that it's fits clean with no JB weld.
Bullit
Spain
2024 Mustang GT AT
Do you know how wide are the holes? (in centimeters)
I'm thinking cover with a gorilla tape or similar in dark color and see the results before buy a covers.
Ryunker
Madison South Dakota
What is the outcome from your dealer interaction?
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
The results will be no more garbage in the uncovered channels. Just get the covers and be over it. 👍
Dealers are still completely oblivious. Just cover them and move on. It doesn't need an episode of unsolved mysteries.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
Agree 100%. The dealers will not be able to do anything until Ford comes out with a service bulletin and a fix. Don't hold your breath. Just fix it and move on.
ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
You got a link?
I think it’s time I do the same
Aside from slinking a vacuum into the hole, has anyone tried flushing it out with a pressure washer or even just a garden hose? Will the debris exit out towards the back of the car or is there no other hole back there? Just curious. TIA...
There is absolutely no need to use water to flush out that area. 🤦‍♂️ Use a vacuum if there is debris and block off the hole. People really need to stop over thinking this.
glenng6
Easton, PA
I did the same using a tape called T-Rex by Shure. See my post
I did exactly that. I used a tape called T-Rex by Shure. I installed mine on May 7. Here is a link to my post: <https://www.mustang7g.com/forums/threads/front-fender-line-holes-gone.167783/post-3370630> My fender wells were very clean when I did it. If yours aren't I would use a hose to get off loose dirt and make sure it dries completely. I am going to wait and see how it works through the summer. So far, the tape looks like it was installed yesterday. If it lasts, I will take the time to clean it up so it looks a little better. If not, I will decide in the fall what I'm going to do. A couple of observations are that the space between the tire and wheel well is so tight that it is difficult to see the tape unless you're looking for it. Secondly, it took a couple of feet on each side, so I can do this many times before I need to buy another roll of tape. If you do buy the T-Rex tape, just be careful because when it sticks to something, it will stick very well. Lastly, I don't drive my car intentionally in bad weather, so my patches are exposed to less abuse than if you do. I am driving to Toronto around the middle of August, and I'm sure I will hit bad weather, so we will see. Good luck! ! Glenn
