Front inner wheel well issues
TUnica
TUnica
South Hero VT 05486
plastic gets brittle and cracks over time though.
Have you had the opportunity to perform the smoke test? Or i should say, been able to take them out for a drive and see how they hold up?
No, the car is going into storage for the winter. I’m confident in the fiberglass but the carpet less so. My hope is that the aftermarket companies start manufacturing the ABS replacement inner fender wells like they did for the 550.
TUnica
TUnica
South Hero VT 05486
When I sold My 69 442 it was 47 years old and it had its original plastic inner fender wells and they had no cracks or splits in them. ABS is pretty durable stuff. Time takes its toll on most things though.
TUnica
TUnica
South Hero VT 05486
my 16 S550 used the fabric material. When did they change it to plastic and then back?
I don’t know? I worked on a coworkers 2018 and they were plastic for sure. Perhaps they were aftermarket?
Vapor Blue GT
Mustang and CRV
That’s some tough plastic. My 05 and ‘13 vehicles had crack front fender liners by a couple of the screws. Never had to remove them. Maybe the temp fluctuations from 100’s to sub zero winters had an effect
FWIW, I checked my S550 earlier. There's a bulge (out) in the same spot, shaped a bit differently, but close to yours. The liner is all one piece. I didn't try to pull it back and look in, as there are fasteners close-by.
Almost makes one wonder what the interoperability over/under lap would be.
TUnica
TUnica
South Hero VT 05486
I sold our 2003 S2000 in the spring which we had 20 years and those to were plastic and they were in excellent shape. Of coarse it helps only being driven seasonally
Vapor Blue GT
Mustang and CRV
We just traded in our 08 solstice gxp and they were fine. It definitely didn’t get driven in the winter.
erocker
Milwaukee, WI.
I didn't notice this on my car when I did an oil change and put jacking rails on. I'll have to check when it's out of hibernation.
While I get a laugh out of the various Flex commercials I can say that on my 03 vert top it worked great. Had a tree branch pierce the top like and arrow. Put some Flex Tape on and it's lasted 2 years with no sign of falling off. I did put it both on the outside and inside underneath the top. I'm going to put it on my s650 when I get it because I remember with my 03 GT the front frame members would collect water and rust to pieces. Common problem. Hopefully Ford issues a fix as this seems ridiculous to me.
