Front Camber Adjustable Camber Plate
How much front camber can you get in the S650 Dark Horse using the Ford camber plate?
The Track Use Addendum says to set it at -2.25°, but we all know that is not enough, so how far will it go?
-2.5°?
-3.0°?
I'm not sure the factory plates go past -3. Might even be less than that.
Ryunker
Madison South Dakota
I have those from ford performance on mine, I modified mine for a fantastic grocery getter. Perfection as I will never take it to a track.
-2.25 is what I got maxed out from the factory plates.
Thank you!
Finally an answer!
That is the Track Addendum recommendation for the front for a track alignment, so it looks like they are recommending what is the maximum.
Odd that Ford would not have permitted more adjustment so long as they were going to install adjustable camber plates.
What is the harm in allowing -3.0°?
Yeah, I remember the factory plates don't allow for as much as some people would like. I had Steeda plates on my Mach 1 and those went to -3.5 I believe. I wouldn't mess with it honestly. Those plates where a headache to install and adjust.
MustangNoob
CA
do you have to do alignment every time you change the camber? I have adjustable camber plates front and rear..never used them
Mod Mustang Racing
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
Yes, because unfortunately with Fords design, camber changes Toe on both front and rear.
For those looking we offer great ways to adjust camber up front and camber and toe in the rear, let us know if we can help!
S650 Mustang Front Camber Adjustable Camber Plate 1777575628410-cu
Technically yes. Although many will say no. While not as critical as Toe, having different camber on one side will throw things off. Especially on a car with wide tires and an aggressive tread pattern.
