First oil change constructive comments appreciated.
Abilor
Albany, NY
@AZ_Ryan ...... you are correct - Ford does not recommend lubricating the oil filter gasket. When I asked my Mustang tech why, he said Ford explained that they were worried the oil filters would loosen under vibration if the gaskets were lubricated. All the techs apply oil as they said they had never seen one loosen and leak and getting one off without lubing the gasket was often a huge task.
Peculiar. I've always lubed the filter gasket, and put the Turkish Headlock on it with my strap wrench. Always assumed the oil gums up a bit, and the seal is essentially permanent. Have never heard of one coming loose due to NVH in 20 years of collective forum lore.
"Kids today, don't even oil their filter gaskets anymore..."
Never left one on long enough for it to get stuck. Is that why you're supposed to oil it?
JohnWimsey
Oklahoma
2025 Dark Horse
My GT is coming up on 1000 miles. I will do my own oil change around that time. I plan on using either Pennzoil Ultra Platinum full synthetic or some kind of Mobil 1 synthetic. Probably the Pennzoil since that's I've used for years with no problems in both my personal vehicles and several of the vehicles my company owns.
Of course my dealer wants to use Motorcraft Semi-Synthetic I think because it's cheap.
Any constructive comments on the Pennzoil Ultra Platinum, which is my preference, and going straight to full synthetic from the factory fill of semi-synthetic would be appreciated. Yes, I know, I know, I did a search. This is 2025 though.
Thanks, FD1
Just asking, do you know what the words full synthetic means on motor oil containers?
Thanks, FD1
I would read the link before you change oil ever again
Royal Purple and Amsoil are engineered the same. I am a Royal Purple fan. Cost less and easy to get
https://blog.amsoil.com/100-synthetic-oil-vs-full-synthetic-oil-whats-the-difference/
Frogdog1
Frogdog1
Dixie
Honda Civic, Toyota Pre-runner, Ford Premium GT
Changing the oil on a GT doesn't sound like Rocket Science. Removing the underbelly cover does sound like a PIA. I'll get 'er done soon.
Frogdog1
Frogdog1
Dixie
I know the difference between regular oil, which is hard to even find, semi-syn, and full syn. I've been changing my own oil for a LONG time.
JohnWimsey
Oklahoma
2025 Dark Horse
On an oil can, "full synthetic" indicates that the oil is made entirely from synthetic base oils, rather than conventional mineral oils, and has been chemically engineered to provide better engine protection and performance. This type of oil typically offers benefits like improved lubrication, better resistance to heat and cold, and a longer lifespan between oil changes.
On an oil can, "synthetic" indicates that the oil is a lubricant made from chemically modified or synthesized compounds, rather than being directly derived from crude oil. This process results in a base oil that is designed for superior performance and protection compared to conventional oils.
Abilor
Albany, NY
Germansheperd
2025 Dark Horse
I’ve never seen full synthetic on an “oil can”.
Cz_Ziemniak
Maine
S650
I heard this article is a hoax perpetrated by marketing shills. Royal Purple ain't shit.
Royal Purple does genuinely have a much higher detergent content than many other oils. Sort of a double edged sword though.
What a lot of people discovered years ago (largely honda guys who wanted le epic purple fluid) was that this oil would clean their motors real squeaky. It does genuinely work in that regard.
The downside is that their 150K+ motors were being held together with sludge and shit, and the moment it was gone, their engines leaked themselves to death. all over, gaskets and seals were now pissing oil. All those dry-ass seals were now exposed to thin, non sludgy, cleanish oil, rather than a thick layer of sludge.
So while RP wasn't exactly *bad*, in that regard, it exposed the need to essentially replace every gasket.
I actually saw this exact thing happen myself, though not because of royal purple. Whole separate story, still dealing with it to this day.
Otherwise, RP is insignificant in its film strength, and the purple color is just dye. Overrated af, you don't need a detergent package that strong if you just do an oil change every 3-5K with any other brand.
Abilor
Albany, NY
This is what happened to the 2021 Camaro 2SS Convertible I bought back in March, though with only 10,000 miles. Something was wrong with the PCV system, which we discovered only after tech mind-numbingly replaced all the seals and gaskets when oil was seeping out of any convenient escape without discovering root cause. But I digress...
Interesting that success could be so caustic for our poor Honda friends...
Cz_Ziemniak
Maine
S650
It carries over to pretty much every car/engine, granted those with more porous casting will experience it worse (looking at you, 60's Ford).
I only learned about it from Honda boys, but after digging saw the same thing with older GM's, Toyota, so on and so forth.
