First oil change constructive comments appreciated.
The concern is that some synthetic oils in the US are not primarily synthetic. They are group 3 base which is derived from mineral oils but are highly refined. Mobil filed suet against Castrol for this in the 90s because Castrol labeled their Syntec oil as being 'synthetic' but was derived 100% from mineral oils. Somehow Castrol won and many companies changed their synthetic oil bases to be derived from mineral oils (or natural gas like Mobil) to save cost/increase profit. Group 4 base oils are polyalphaolefin (PAO) synthetic base oils. Additives can be other group oils. I do not know if there are any full group 4 oils out there but Euro spec oils are the highest % group 4.
Now all of this said, without testing, you do not really know how the oil is performing for your use. Group 4 base oils will out perform Group 3 base oils but you may never wear out a Group 3 base oil depending on how you drive or how often you change the oil.
Ford recommends their semi syn oil for this engine and oil change interval (10k miles or 1 year) so any synthetic oil that meets or exceeds the same standards is going to be good. I use the full syn motorcraft in the mustang. All of my other vehicles get Castrol, Pennzoil, or Valvoline (VW Euro spec).
Also, the number of fasteners to remove in order to do an oil change is painful on the mustang. My 2012 Xterra had an access panel on the skid plate to get the filter. Granted that was in metal vs plastic. Maybe that would be a worthwhile product to bring to market to reduce the labor for oil changes. As the plastics age, they will lose shape and be more of a pain to realign.
The S550s had an access panel as well.
Cruiser
Idaho
2024 GT PP
My GT is coming up on 1000 miles. I will do my own oil change around that time. I plan on using either Pennzoil Ultra Platinum full synthetic or some kind of Mobil 1 synthetic. Probably the Pennzoil since that's I've used for years with no problems in both my personal vehicles and several of the vehicles my company owns.
Of course my dealer wants to use Motorcraft Semi-Synthetic I think because it's cheap.
Any constructive comments on the Pennzoil Ultra Platinum, which is my preference, and going straight to full synthetic from the factory fill of semi-synthetic would be appreciated. Yes, I know, I know, I did a search. This is 2025 though.
Thanks, FD1
Check out the Motor Oil Geek on u-tube. He is a wealth of knowledge.
@Abilor ..... very interesting, brings back memories. We used to use through the dipstick oil tube extractors for our marine engines. We knew we weren't getting it all as that is simply not possible with that system. Used it for thousands of oil changes. As we built more and more expensive marine engines we had to make sure we were extracting as much oil as possible - aiming for 99.99% After using our typical dip stick tube oil extractor we removed the plug from the oil pan. The tech started yelling for some rags as oil was draining into the boat's bilge. Note - the bilges on racing boats are pristine and owners get really pi$$ed if there are dirty oil stains in them. Now what, we wondered? We found brass 90 degree angled tubes that we could screw into the drain pan plug holes. Note - when we "dry fitted" the brass piece we noticed it stuck above the bottom of the oil pan depression by about 1/4 inch so we cross cut the brass fitting to allow maximum drainage. We attached custom fabricated stainless steel braided hoses to the brass fittings and ran them up into the engine bay and topped them off with an on/off valve. They were then affixed to a stainless steel mount. To change the oil, which was done after every race or even a hard weekend of play, we used a custom electric vacuum pump. Doing this we got all (99.99%) of the oil out of the pan. The oil filters were on remote mounts on the top of the engine. A friend who saw what we did modified all of his shop trucks (he had 25 or so) with this system and it saved his mechanic a $hit load of time and therefore money. I am sure using your through the dip stick tube is good enough for what we forum members do as we don't have to get all the oil out ..... so I write the above just for amusement.
Abilor
Albany, NY
I am indeed amused! It's amazing how much innovation comes from simply having a go with what's laying about!
And yes, what I lack in leaving perhaps as much as 5 to 10% I think I make up with frequency, changing when indicator gets down to about 33%
No Forum Members were injured or killed in the making of this highly controversial thread topic (again)! 😉😆
PS: Good luck with your oil/filter change OP! 👍
Frogdog1
Frogdog1
Dixie
OK, another question. I already know one answer is "personal preference" but why do so many people put a catch can only on the passenger side? What is the "technical reason", not the personal preference reason. Bear with me, I'm a first time Coyote owner but not a first time "fasty car" owner.
Thanks, FD
Mastermind46
Denver
How hard is it to get to the filter alone? The reason I ask is that I use a vacuum extractor for my oil changes. I dip a long tube through the dipstick or oil port itself, and it can handle nice high temps as well, so you get the advantage of heat-happy viscosity.
Once extracted (two loads, with 10 quarts), all that remains is the filter... Any easier? Anyone else doing their changes this way? I effin' love my vacuum extractor, had it since my VW Golf R days...
IIRC it is 15 or so screws, 2 self destructing Christmas tree style clips, and 2 reusable clips.
I have never used an oil extractor but see them all of the VW and Audi forums/FB pages. I do not understood why. My wife's VW is the easiest oil change. That whole top mounted oil canister setup is awesome. The single use $10 plastic drains plugs are not awesome so maybe that’s why. I would think the mustang would have a lot more people using them since it is a pain and can make a mess.
Abilor
Albany, NY
The top mount oil filter was the best part. Oil changes on Astrid (our Golf R) never required you to get under the car. Just extract, replace filter, pour in the good stuff, dunzo. Swore I'd never use an oil tray again after that. Vacuum extractor FTW.
As they said in Top Secret: "You've got to hand it to the Germans, they make great cars..."
Thanks, FD
That's the clean side and you generally won't collect anything if you put a can on that side
@AZ_Ryan ...... you are correct - Ford does not recommend lubricating the oil filter gasket. When I asked my Mustang tech why, he said Ford explained that they were worried the oil filters would loosen under vibration if the gaskets were lubricated. All the techs apply oil as they said they had never seen one loosen and leak and getting one off without lubing the gasket was often a huge task.
Not lubing the gasket but applying a light coat just enough to create a seal. Not trying to make it slippery but rather freshen it up wipe the dust off style of coating.
TX-TBeau
Round Rock, TX
2025 GT 5.0 6MT, 2018 Accord 1.5T 6MT, 2018 WRX 2.0T 6MT, RAM 1500 5.7 Hemi
Thanks again, Skye! Lots of good information here.
I spent too much on the car to not take care of it. I'm rather anal about taking care of my things.
Me too! Pride of ownership AND you're not just paying someone to do the work, you're doing it. Guaranteed you will do a much better than a paid mechanic UNLESS the job is beyond your skill or knowledge. Oil change is not that.
