mks
- Thread starter
- #16
Just trying to keep up with proposed solutions...please mod, add or subtract at will.
I may be thinking of this the wrong way, but I feel increasing ride height is less a viable objective than to have springs designed to support the increased weight of the front end with the SC installed.
- A legit front spring set designed to support the added weight of Whipple SC on S650s (all variants)
- Coilover conversion kit, a al AJ Hartman’s S550 Kit (also heard Ground Control makes something in that fashion) for S650
- Edit: Strut mount Spacers e.g., Steeda’s kit combined with Steeda's dual rate springs (caveat: not sure the shim kit is compatible with the adj strut mounts included in the 67P handling pack)
- Note: there are polyurethane or rubber coil spring spacers/isolators, but I don't think these are something I’d even try
- The great weight shift: moving battery (44.9lbs!) to trunk, replacing OEM metal bumper w/a lighter weight version (again, another Steeda product), and any other "fat" under the hood
- MagneRide-compatible or MagneRide-delete Adjustable Coilover Kit
- Create a stock portfolio design to produce enough monthly (weekly?!?) dividends to afford replacement front splitter for the rest of the life of your S650
