Coyote Engine Advice
Jetfixer
SW Ohio
2025 Mustgang GT Priemum 401A 2017 F150 4WD Lariet 3.5 Ecoboost
Let me say first of all that I’ve been driving cars and trucks with manual transmissions for over 60 years. And yes I’m old. However the recent purchase of a very low mileage ’25 GT is my first experience with a computer controlled engine mated to a manual transmission. In the old days engines would protest loudly when lugged by pinging, knocking, shuddering, etc. However this new to me V8 seems to be very happy from almost idle to redline. I try to keep the rpm above 1500 unless it’s on a perfectly level stretch of road. And even then I’ll drop down a gear or 2 depending on terrain or circumstances. So, do I need to worry? Keep the rpm‘s even higher than the 1500 minimum I’ve set?
I have a V8, Manual Transmission as well.
Lugging any engine is a valid concern. But I would not rely on an minimum RPM to help alleviate that.
There is a distinction from previous engine generations and today's. Years ago, it was left to the driver to determine if lugging was occurring and then to take action. In today's engines, lugging does still happen, but the computers take often action before the driver notices.
While modern systems act quickly and in the background, the physical events of Low Speed Pre-Ignition (LSPI) still occur. If the problem is bad enough, misfire events can be recorded, the car throwing a wrench light (engine issue, code/s recorded, take action). Long-term, the risk of damage is still there.
I looked in the 7G manual for shift recommendations for a Manual Transmission and couldn't find any. Looking at the 2022 owners manual, there are some (attached). These are based on speed and not RPM. I think anyone could use these as an initial basis for regular driving in town. These are guidelines and not hard rules. Notice these are also mentioning fuel economy.
While I have a performance shift indicator alarm set, that's for when I'm wringing out the car. When I'm driving the vehicle in a normal manner I rely on the sound of the engine and feel of the car to determine when to shift. IDK, it's just something I do. As with other cars, you'll develop your senses when it's best to shift this car.
If the vehicle is struggling and under-responsive, I know I need to go down a gear. If I look at the tach and it's above 3,500 RPM while driving normally in traffic, I go up a gear. Shifting...on average, I probably make shifts around 3,500 - 4,000 RPM. The car is not struggling, but not wailing either. It's a behavior where I'm not looking at the tach. From feel, sound and experience, I just know when's a good time to shift. The times I have been found lugging, it's often on a new stretch of road I'm not familiar with.
When starting off, it takes a bit of time before the engine is warmed up and temperatures are stable. In these instances, I keep RPMs below 4,000. There's no official reference for that. It's an RPM I've felt is good to move around with, without stressing the engine while being warmed.
If I've started the car after a stop, I'l look at the engine temp. It'll often be higher that usual, sitting with no use of fans or airflow. In these examples, I'll drive similarly to the paragraph above. Easy on the engine until temps return to normal.
Driving in traffic, steady speed and cruising, I'm probably at 2,500 RPM. If I'm pushing the car, anticipating winding the engine up and moving, 3,500 RPM. My engine comes alive about 4,000 and higher.
Those are some general ideas. I'd move away from an RPM operating floor and rely on how the car is behaving, sounds and acts.
The Coyote likes to rev. Don't be surprised if the car is driving well and the RPMs seem higher than they would with other vehicles. Compared to my Mustang, driving my truck is like driving a tractor: operating RPMs are much lower.
Another thing you can do to support this is use a quality Top Tier fuel, the highest octane you can find. The higher the octane, the greater spark advance and power. But it also helps in another way: reduces the risk of LSPI by increasing the point at which the fuel could spontaneously ignite.
https://www.toptiergas.com/
S650 Mustang Coyote Engine Advice Screenshot 2026-08-03 at 02.02.56
Charger68
Willoughby, OH
Most AT cars will cruise at 1200 RPM in high, but a torque converter helps. I think you're smart enough to know when you need to down shift before applying generous throttle. What I notice is with a 3.55 rear end and 1.42 3rd gear ratio, I'm able to make casual turns in 3rd gear sometimes.
Ninjak
Posting from the Shadows
The Shadows
Running a boosted 6-speed manual. I been driving stick for a long time; I always keep the power in the band to keep the vehicle operating smoothly. If I am driving around town, I will drive in the gear that helps it respond quickly. I have the 3:73 gears.
In traffic, I usually drive around in 3rd or 4th gear. On the highway in traffic, I will drive in 4th or 5th gear. Of course, for regular highway cruising, you are in 6th.
What you’re noticing is the miracle of variable cam timing in these newer engines it’s not like you were running a static profile.
You don’t really have to worry about lugging like you do with like an old high lift solid roller set up. At low RPM the intake cams will advance and help Bring the extra air needed and then it’ll retard out as you extend RPM.
hal26
Central Texas
2024 Mustang Gt
I usually run at 1600 to 2000RPM to keep a light load on the motor. I do not use 6th unless running at 65 mph or more on FLAT ground.
the Coyote family of engines are basically only a couple steps short of race engines on the road, especially due to that 7500rpm redline on a cross-plane V8. that being said, they're still designed to be able to handle everyday stuff too, since the Coyote is also in the F-150. modern technology like the independent intake and exhaust valve timing make it so that even if you're using 87, you're not hurting the engine, just probably making less power. from what i've seen and heard, as long as you're not abusing the engine to within an inch of it's life and take care of what it needs, it seems to be pretty problem free. there's so many things controlling the state of your engine and it's performance, and any OEM has pretty much covered most or all cases within the programming. back like 40,000 miles ago i had some fun and managed to get my oil temp to just shy of 270 degrees, and i've had no major problems with the engine, other than one exhaust valve guide seal leaking oil pretty early into life, but i don't think that was related to my use of the engine.
point is, you're almost certainly just fine
Racer57
Illinois
2025 Shelby GT350
But it was really cool to brag about having a 3/4 or full race cam, with solids ! Now days, does anyone get a thrill talking about a computerized cam ? :D
Even better when they actually do put higher lift cams in and then say where’s the chop?
Achlys
KC Metro
Forged piston, shot peen rods & roller rockers, high lift cams = engine porn. Just stop it🤔
Achlys
KC Metro
those shift recommendations are insane. the shift to 6th at 48 is the most ridiculous. even on the highway I seldom use it except it is really empty and it's just free cruising.
But are they?
Really depends on the driving experience.
Casual drive or a spirited power at the calling drive.
I have the A10 with 3.55 gears, driving 40 miles mostly highway & a little city, the car wants to level out at around 1800rpm at around 65mph. When I'm nice to the throttle, I get around 24mpg; when in sport is goes down with the throttle response given. The car is not bogged down, yet if going up a hill too much, the throttle will require a downshift. So to put all this in perspective, my previous daily driver was a Honda Fit, which was ALL about MPG, cause power at 153HP is lame in comparison. So crusing along with 486HP is a breeze. Heck, I passed a couple of vehicles that couldn't figure out the speed limit and hit 120MPH. :cool:
OzzieRoss
Perth - Western Australia
2024.50 Dark Horse
Our 2024 manual DH has a shift indicator in the dash. Admittedly I only use it as a recommendation though . . .
