Clunking noise from the transmission when slowing down!
thornclaw
northbrook, il
2015 mustang gt
Applying grease to my transmission output shaft splines and the I.D. of the output flange splines resolved my clunking noise. The output flange is connected to the driveshaft. Mine has the stock exhaust. Only takes about 15 minutes to apply the grease if you have a lift. Good Luck
can you detail how the job was done? specifically how did you get the flange off?
Cobrakit
Southern Maryland
2019 Mustang GT PREMIUM PP1
You can take a look at this Ford TSB from 5 years ago. Same issue and same fix. Very detailed.
Do you have a copy of the WSM, Sections 307-01 and 205-01, as called out? The output shaft flange P/N needs to be updated for your vehicle.
Will2
'26 Mustang GT
Not that poster, but I believe the part is: JL1Z-7089-B
Also curious how to DIY this.
slip10
wisconsin
2024 Ford Mustang GT, 2025 BMW ix
I noticed that I do not get a "clunk" when it is in sport mode. Any one else seeing this?
Will2
'26 Mustang GT
If you have continuous gear display enabled, I would monitor the gears to see if it's going 3 --> 2 --> 1 in Sport mode, versus 3 --> 1 in Normal mode. I would get the clunk when it downshifted from 3 --> 1.
WrekEE
FL
DH, SQ7, TUNDRA TuRD Pro
My DH automatic is in the shop. I gave them the info for the TSB's. They are saying its a bearing issue in the rear differential. and Part is backordered to May 10th. So it sits.... and i wait. And then i will probably have to tell them to do the TSB's if the clunk is there. Sucks... i only have 500 miles and haven't really been able to drive it hard.
D/\rK•650
2025 Mustang DarkHorse
Sorry to hear this. Mine had the clunk and they fixed it so far its ok. They greased the output shaft. I guess your has a different issue though. Goodluck with the fix.🤞
Mine GT PP goes 1-3 3-1 even in sport mode
The grear selection is throttle dependant. That said mine only skip shifts in normal mode. Also the transmission does take some mileage to learn your driving habits and smooth out. Sport mode in mine was super touchy at first. Now its really nice.
Cipis
czech republic
Mustang GT
I believe it is throttle response related. Honestly, I never go hard from stop. That is maybe why my trans. shifts over 2. even in sport.. … 🤭
Will2
'26 Mustang GT
When I had this issue on my '25 GT and would listen very carefully, I could also get the noise accelerating slowly from a stop. Whenever I hit 2-3mph either slowing down or speeding up (1-->3 or 3-->1) it would make a clunk and you could feel it in the floorboard. It would even sometimes happen ~17mph from a different gear change, though you'd have to be sensing extremely carefully in a quiet area (and without extreme exhaust mods) to notice.
The Ford Expedition/Navigator TSB 20-2253 posted in this thread fixed it, or at least the sound became quieter and more of a "chuff" sound at the 1/3 or 3/1 shift. Now on my '25 Eco I also hear the "chuff" on 1/3 3/1 so I presume this is a characteristic of the 10R80.
What I call the "5th gear stumble" is another characteristic I've noticed on the 10R80 on multiple Mustangs.
marcus50
2026 Mustang Dark Horse
I've also noticed this clunk when it is warmed up in the same speed range as described above. It does not do it all the time but quite often. When rolling to a stop in N there is no noise.
Main point "if you have a lift" (I wish 😄)
It seems that you have to mark where it sits, remove the four bolts going to the driveshaft and a center bolt holding the output flange in the transmission, is that correct? The bolts are one-time use according to Ford but looking up pictures of them it seems they come with Loctite preapplied and there is no angle measurement given for the tightening torque which would point to "real" one-time use TTY bolts. In my opinion the "one time use" here comes from the fact that the factory applied Loctite on the screws is broken once you remove them and new bolts come with unused Loctite on them.
