Check your swollen nuts!
Sf22giants
Recently replaced all 20 lug nuts on my 2024 Dark Horse. Also replaced all 20 on my 2016 GT. The DH had no issues but I had to use a 21.5mm socket and a hammer to work on the 2016 GT. Those nuts were swollen real bad!
It seems as though Ford still uses two piece lug nuts from the factory, which end up swelling at some point. Once they’re swollen, it’s a bit of a challenge to remove and replace them.
I replaced everything with one piece lug nuts on both cars. Now they’ll never be a problem.
I used Chrome Gorilla lug nuts for my 2024 Dark Horse.
I use Black Gorilla lug nuts fo my 2016 GT.
Don’t forget to check your nuts; it only takes a few minutes!
ZXMustang
tooner
2025 ESS G3 Mustang GT
The metal casing mushrooms when they are tq'd on too hard. Then they expand and no longer fit the correct size. The metal core is still good, but they can sheer off the outside then good luck getting them off. The jeep wrangler has those that do the same if they are pounded back on with an impact gun.
Achlys
KC Metro
Keep a future eye on the Gorrila lug nuts they tend to rust over time. Using hand tools rather than impact will help make them last longer. Please do not use anti seize and hand torque the nuts to spec. 150 foot pounds.
What was wrong with good old normal one piece nuts? They've served me well for several decades
Usually thanks to powertools on the nuts...
Yea. You should always be really careful about letting anyone else use power tools on your nuts (presumably; you'll be careful if you do it yourself).
BoostRabbitGT
'19 EcoBoost (101A)
That (and this thread in general) is nuts.
