Battery tender - no bonnet lift needed?
2026DHCARB
Chile
Mustang Darkhorse
Dear all, any ideas on how to install a SAE cable for a battery tender as a no lift bonnet solution?
Thanks!
Neggytive
let it hang down and secure the pig tail with zip ties.
You'll have to reach/crawl under the car to access it.
Just make sure it is fused as close the the battery as is possible, Battery Tender brand chargers have a fuse holder and 7.5 amp fuse near the ring terminal
Alex381
I like having the hood popped a bit. Makes it simpler to know when it’s plugged in. way less likely to rip the tender out of the wall outlet.
2026DHCARB
Chile
Mustang Darkhorse
Thanks! I do have a fuse, but want a more comfortable location for it. Ideally in the grill or on the edge of the windshield close to the battery. A intermediate comfort location would be on the wheel well, easy to install a “socket”, but dirty and cumbersome to plug and unplug…
2026DHCARB
Chile
Mustang Darkhorse
Haha, been there, but I must admit I reversed with the hood popped out a bit…
TMR
NC
'26 Mustang GT Vert, '21 F150 KR, '25 X5, '25 X3M50
Here is my install on a Ford Performance/ Vtech charger. I had no issues running the connector under the hood near the headlight. But I do have to open the hood to connect it.
Not exactly what you are looking for.
You will have to shop for a battery connection with a tail long enough to reach the grill. Personally, I did not find a connector or extension that long in the brands I looked at.
S650 Mustang Battery tender - no bonnet lift needed? IMG_3049
On my S550 I had a small pigtail lead that sat under the rear of the bonnet near the windscreen. Not visible but easy access. On my S650 it is like the above pigtail.
Different generation, but I fabricated a simple extension of the existing pigtail, then ran that to the front. There's a gap in the headlight area the cable runs past. I use a small piece of foam, wrapped around the extension, to protect it from getting nicked. The extension uses the same gauge wiring and adds two some-odd feet, 1/2 meter in length.
The plug is weatherized. I drive with the dongle exposed like that. If I like, I can pop the hood and just put the plug in the engine bay.
I'd stay away from the windshield area. The tray there acts as a water collector/run-off area.
Agree on checking to ensure its disconnected before leaving. "WTF is THAT sound!?" :giggle:. In my example, the cables disconnected as seen in the photo.
S650 Mustang Battery tender - no bonnet lift needed? 20220629_1415
S650 Mustang Battery tender - no bonnet lift needed? 20251005_101436
S650 Mustang Battery tender - no bonnet lift needed? 20250517_073642
It might be practical to take a 4" x 6" card and write on it, "Unplug trickle charger!"
That one and another: "Remove wheel chocks!". :giggle: Have a good week everyone! :thumbsup:. :fistbump:.
XUV
Australia
GT Nite Pony
I have these cigarettes Sockets, on my cars that don't get driven as much
Our Stang is her daily , So no need
I put them on front air dam. The one Under the number plate
Works well with the Ctec supplied cigarette socket plug and pull straight out if you forget about it.
They blend in well , and if you ever get a flat battery ,
you can just plug an external battery in and get into your car
S650 Mustang Battery tender - no bonnet lift needed? Screenshot_20260623_003945_eBay
