Anyone know what this noise is ? 2 dealers didn’t …
A.alansari
Qatar
Mustang GT 2024 PP
i have the same exact sound on my car and it was there at the show room before buying the car i think its normal
i asked the dealer about it before buying and then i asked the mechanic when i went for service about it and both told me its normal, they even started another car for me to make sure its there as well
Dxm
San Antonio
On my old Mustang there was the clutch plate rubbing against the clutch housing. It got worse and worse throughout the years until the metallic noise was horrible. It happened at cold starts, and would fade out within a few minutes. The fix was to remove the clutch cover, add a couple washers to give it clearance and put it back. Not sure if this is the case here. Is it manual? If so, could be the clutch.
It could also be one of the pulleys. You need to get a stethoscope and listen where it's coming from during cold starts.
Jdio
2024 gt pp 2018 gt350 2003 cobra
Definitely a belt/bearing noise.
The dealers must have narrowed it down to the drive belts or in that area if they replaced parts in that area... I still say alternator pulley... modern alternators use a "freewheel" pulley which drives the belt under acceleration, but allows the alternator to freewheel under deceleration (or idle down). Sometimes they can emit some noise while doing so... excessive noise may indicate it's faulty.
Aegean
Northern Virginia
2024 Ford Mustang Ecoboost - Dark Matter Gray Metallic
Thank you for updating us. Looks beautiful. Did Ford provide a rental for some of the 73 days?
Petes24Gt
My2024mustanggt
2024 Mustang gt
So...did you ever hear back from Ford on a Buy Back?
We settled with a cash for keep, I can’t disclose the amount as part of the terms of the settlement👍🏻 I can say this , it was brutal going through it, but Ford stuck by me and did right by me. I’m happy now that it’s over got my Horse back , happy af!
Petes24Gt
My2024mustanggt
2024 Mustang gt
Because Ford goes to great lengths to reduce NVH on these cars.
So I found it odd that an operator would go out of their way to listen/look for it.
Anyways 100% normal and to be expected startup sounds from a combustion engine.
Enjoy 😉 👍
Hey know it all , not normal the timing chain guides and tensioner were the cause… thanks for caring .
I’m still suspicious of placebo effect, but if you’re happy, I’m happy for you!!
Petes24Gt
My2024mustanggt
2024 Mustang gt
arrogant
E A D sweetheart , and try not to be such an arrogant ahole. Enjoy that pie all over your face, learn something .
I'll be interested to see if this topic develops into either of the following over the coming years:
- Ford Technical Service Bulletin. Inspected parts determined to be wearing abnormally should be replaced
- Ford Special Service Message. Like the BBQ tick, the sound is considered normal
OP,
Happy to hear the issue was resolved. :thumbsup:
Mr Hyde
florida
2024 mustang GT
Sounds like a pulley or belt noise. Does it come back after the car drives or accelerates.
