ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
Just finished the Pioneer sub upgrade.
Pretty easy with a Dremel and metal cutting wheel.
Definitely a worthwhile upgrade.
Ended up costing my wife one throw pillow… lol
Thanks for all the tips!
Nolasalt
NOLA
Appears the consensus is most feel this is a worthwhile upgrade. But the realistic expectation is when listening to anything other than boom boom music in the "6-12" volume range the difference will be minimal.
I'm in the rock/country crowd.
I tried poly-fil with the factory B&O sub since I had good results in my 2010 F150 with the factory Sony sub. But it was a complete waste of time.
BuckeyeBOSS
I decided to give the DD Audio SW10-D4 a shot.
  • Like
Reactions: exm
GrabThatBlue
Between Canada and Europe
Did a little upgrade on the stock subwoofer after following a thread on the s550 forums. The pioneer replacement subwoofer was only $79 and took less than an hour to do!
Sounds tighter and more crisp than the OEM subwoofer.
Honestly kind of surprised with how much better it sounds over the crappy cardboard subwoofer that comes factory.
I figured I would make a video on the install because I couldn't find one and its just easier to follow along a video than sift through 40 pages of a forum thread
initial thread: https://www.mustang6g.com/forums/threads/b-o-10-sub-replacement-guide.148813/
Man I started to watch your video since I never saw a video on how to do it but unfortunately it was not what I expected. 1 shot the subwoofer was there and another shot the subwoofer was out. I was hoping to see on how to do it.
exm
Long Island, NY
I have a 3D Printed Subwoofer ring plus speaker grill for sale in case if anyone is interested here
85GT4V
N C
‘85 GT4V, ‘97 F350 Dually, ‘26 EB Premium
I felt like this was a no-brainer first project. Relatively inexpensive, relatively easy, reportedly meaningful results…what’s not to love?
Very easy project start to finish. Pioneer speaker is down to $70 on amazon. I had some left over fiberfill and generic dynamat left over from another project.
First observation: FoMoCo’s purchasing department should be ashamed of the components they’re sourcing for the expensive, “upgraded” B&O system. The system is honestly underwhelming.
Comparison photos between the OEM and Pioneer:
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1687
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1688
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1690
Installation was straightforward and even the clips holding the trim ring were not too bad. Stuffed the interior of the cabinet with fiberfill and covered the exterior with dynamat.
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1691
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1695
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1693
Got the enclosure reinstalled and eagerly fired up the system…
Something’s got to be wrong, I can barely hear the bass. About what the stock driver sounded like. Surely I’ve got polarization wrong or bumped a wire loose. Tore the whole thing down and started from scratch. Even A/B’d the OEM unit and the Pioneer.
Everything checked and reinstalled…still lackluster.
Now, maybe it’s just the music I’m listening to (70s/80s Yacht Rock) and/or the listening level (volume at 10-12) but, this was not an upgrade. Still glad I did it to get a project under my belt but, if you’re on the fence maybe there’s another project to tackle.
I have a JBL center speaker for the dash inbound. I’ll put that in next week and keep my fingers crossed for a noticeable improvement. Amazon links:
Driver
Harness
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1696
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! IMG_1697
Fruitstang
2024 Mustang GT Convertible
What you observed is what most other disciples of that super duper bass upgrade cheerfully describe as "wow, less boomey and way more precise, now the lower door woofers really come to life".
In fact, sensitivity of the Pioneer is one of the smallest on the market, one would need much more power to get something out of it.
The minimum thing you should do, if not done already, deactivate with Forscan ESE, the electronic sound enhancement, because it uses the sub to fake more V8 rumble. To achieve it best, once the engine is running, music bass signal gets the back seat and will be cut off to allow for fake rumble.
Driver
Harness
You now have controlled musical bass and not boom.
You may need to turn up the bass in the equaliser plus the source makes a huge difference to the overall quality.
This upgrade is not about huge bass, it is about better quality
Driver
Harness
Ohm match? Is your box too full?
BuckeyeBOSS
I went with the DD Audio SW10-D4 10" Dual 4-Ohm 600W High Tuned Subwoofer. DEFINITELY more boom at higher volumes and more punch.
Also, I drove the car with the entire sub box pulled out while changing speakers and there was zero difference with the interior sound of the engine. I always have the exhaust in track mode, if that matters.
exm
Long Island, NY
I have the same sub and it definitely is a major upgrade. Tight controlled bass. I feel that the Pioneer's sensitivity might be too low if people don't change the EQ settings.
85GT4V
N C
I twerked with the settings and got it to perform a little better. Really comes alive at volume level ~18+ but, that’s not where I’m usually at. All in all, for me, it’s a meh.
@Fruitstang , any idea if “calm” exhaust mode may be a backdoor to disabling ESE? I don’t really care what the exhaust sounds like. Perhaps calm would disable any fake exhaust rumblings : )
System
Western Ma
2025 Mustang GT Convertible
That is because the ESE comes from the sub.
you have to do it with FORScan. It’s a 5 minute job and gets rid of the mud in the audio. However, once you do that an amp and loc are really a worthwhile investment…
85GT4V
N C
You have to do it with FORScan. It’s a 5 minute job and gets rid of the mud in the audio. However, once you do that an amp and loc are really a worthwhile investment…
Thanks @System! I’m just an old fart trying to round out the bottom end on some Yacht Rock classics 😆 Being a bass player, I wanna be able to follow that bass line : )
Anyone with FORScan in NC willing to do a couple tweaks on my DD?
