Pyroguy
Wisconsin
Waiting
When I first opened the manual on one of the pages it stated that start/stop is always on and can't be turned off. Then I found this page later. (see attached) that seem to say otherwise for manual tranny??
Also wondering about this for a manual. This would be very annoying.
Pyroguy
Wisconsin
Waiting
Found this in the adaptive cruise section page 215. So...no front plate then? I'm not putting one on anyway.
The radar sensor is in the lower grille.
Note: You cannot see the sensor. It is
behind a fascia panel.
Note: Keep the front of your vehicle free of
dirt, metal badges or objects. Vehicle front
protectors, aftermarket lights, additional
paint or plastic coatings could also degrade
sensor performance.
sdsteele2
Tennessee
24 Mustang GT
sensor performance.
It’s in the middle of the lower grill. Don’t worry your plate will still fit and it will work just fine. 😁
BlackFerret69
Kind of hard to switch it off or on without the button on the dash. I haven't seen a GT or Dark Horse in any of the videos with it installed.
So this leads me to believe that if the button is installed you can, if not installed you don't have it and can't turn it on.
Rio Lobo
MS
Civic Si
No lift shift is on the Dark Horse, not on GT
BlackFerret69
The Dark Horse gets one shipped loose with the car for the customer to install.
EDIT: Removed incorrect data.
BlackFerret69
BlackFerret69
The mixed info on this is annoying :). I've heard from YouTubers:
- both have it
- Only DH has it
- No mention
I'm with you! It seems everything we get a bit of info, it is contradicted by someone. The main problem is Ford constantly contradicting themselves!:angry:
5.0ALM
Brisbane, Australia
Also curious about this.
S650 Mustang 2024 Mustang Owner's Manual Released Captur
The [incompatible] catch can referenced above requires hands-on emptying, as you would expect.
S650 Mustang 2024 Mustang Owner's Manual Released Capture2
How does "self-draining" work with the new can???
It simply reaches a level and then drips out through the engine bay onto your garage floor or driveway? :shock:
