2024 - Brembo Differences
rijndael
VA
2024 GT
I just picked up a new Mustang with the 401A package. Carmine Red interior, Vapor Blue exterior, GT.
None of the features on the window sticker call out a Brembo option, but the front caliper has a Brembo logo. Is this just the default brake for the 2024 GT with my package, or is there some option I got that was unlisted? Are the upgrades just more pistons?
S650 Mustang 2024 - Brembo Differences 1729898298269-uv
LoneRanger57
San Diego California
2019 Ford Ranger Lariat, 2024 Mustang GT 5.0 order
Brembo is the OEM supplier for all Mustang brakes, PP packages provide upgraded calipers and larger rotors and for me was worth the $5295 PP cost 😀 👍
Awesome! Glad you got what you wanted! 👍
Radiant
East Coast - United States
The performance package Mustangs have an extra set of calipers on the rear wheels. Worth noting if you're putting the car sideways, as the Torsen lock-up and torque vectoring change the steering after you flick it.
cosmo73
Berks County, PA
24 GT, 20 A5
Correct, those black “calipers” are for the electric parking/emergency brake. They are not part of the hydraulic braking system.
Radiant
That would be for the parking brake, wouldn't it?
Yes, and for the Drift Brake mode. If you kick out the rear hard in Sport Mode, it'll use every system at its disposal to try to keep you from spinning further. You can feel it hit an "electronic wall" where all the safety system are like "uhhh, buddy? Watcha doin?".
Put it in the Track mode, enable the Drift Brake, flick into a turn and use the drift brake to manage the torque vectoring, and all those same system are working with you, rather than fighting you.
POHLHAMMER
Wisconsin
My question is for those who have the "Big BREMBO" Brakes , but no PP.
How close would the std little brake switch work , in comparison to the funky "drift handle" brake switch ?
Would they essentially do the same thing ?
Or
Does the "Drift handle" switch have different BCM settings ? I Kinda assume it would.
Basically, can I get similar results as the Drift handle by using the std little switch our car has , since it has the auxiliary rear brake the PP comes with ? (granted it wouldn't be as cool 😎 or easy to grab)
Just Something I have wondered about.. 🤔
Or
The drift brake is only available with the PP... the PP brake lever works differently than the standard toggle switch.
POHLHAMMER
Wisconsin
So it has the extra brake like the PP , but it uses it differently, is what you are saying ?
I was thinking they essentially did the same thing , only the fancy handle made it more realistic. Wierd to have the extra brake caliper , but not have it work similar. Idk though , so why I ask.
Thanks !
Farmer Fran
2024 GT Premium Vert
I did not want the PP but wanted the Brembo Upgrade (same brakes as the PP) and I got lucky on mine that it checked all the boxes. But I looked and looked and looked so I understand, you have to make choices.
keithwalton
N/A
2024.5 Dark horse, SLC 250d
Thanks !
The extra calliper is the electronic parking brake (replaces the mini drum brakes inside the rear discs or actuation of the rear brake pads) it has zero function on the drift brake.
It’s most likely the rear bembo doesn’t support electronic actuation as it’s a multipot (4) design.
The drift brake uses the abs controller to apply hydraulic pressure to the rear brakes only through the normal callipers.
The handle acts like an analogue / variable input and not an on / off switch. The harder / faster you pull on the handle the more pressure it applies to the rear brakes. But only when in drift mode. In normal mode it operates the electronic parking brake on or off
