2021 MUSTANG (S650) - 7th Generation Mustang Confirmed
EJS2016
Alpharetta, GA
2016 Shadow Black GT Premium, 6A, 3.55 / '08 GT
Sketch #1 certainly represents the size, dimensions and styling direction I am expecting for the S650.
#2 however, looks like an ‘05-‘09 S197 that’s been modified Hot Wheels style...no thanks.
Kevin08
Panhandle FL
19GT
Yeah, those are in no way in line with what it'll look like. The second one is definitely off...the artist went as retro as possible and it's obvious that Ford has completely moved away from retro styling.
People should just photoshop the 2018s and make the proportions/confrontational designs even more exaggerated and that's probably what we'll get for the S650.
mikeyjobu
15 GT PP
I expect it will be somewhere between SN95 and S550 size-wise, and it will hopefully get the F150 aluminum chassis treatment. Design-wise, I look at the facelift for 2018, and keep thinking about the 4 gen Camaro versus the 5th gen. I hope they keep more Mustang elements in the design than they did with the Foxbody. I do think the S650 may have a lot of the same design elements as an Aston Martin -- that wouldn't be so bad. Does anyone know who is on the design team, and what other projects they have worked on? I do like the retro rendering -- the last on Topnotch posted -- I could really go for that! More S197 than S197, more S550 than S550.
DickR
Raleigh
2018 Ruby Red GTPP MagneRide 301A 10A and 1997 GT
Much as I would like a smaller mustang again (we like the size of our 97 GT compared to our 2015 GT) how do you think Ford could shrink the S650 from S550 dimensions and still "fit" American buyers while keeping "sporty 2 door coupe" styling and having enough room for performance size wheels, tires, brakes, etc? Give up on the back seat and/or trunk, at least in hybrid versions?
Patio208
GT350 Member
Chicago
2020 GT 500 #L2287
I want to see Ford do what Porshe does aesthetically. A Porshe just looks like a Porshe no matter the model year but they still look cutting edge. They don't throw out what works for the sake of change. Chevy also does this well with the Corvette. On the flip side, Chevy F'd up their attempt to do the same with Camaro. It esentially is the same Transformers Camaro but with great bones underneath. I understand that Porshe is niche or rare vehicle and more imune to market presure and competition to constantly offer changes to move units.
Things like big wide grills, headlight gills, fastback silhouette, and tri bar tails should always be evident. We've had a good run since 2005 with Ford offering a modern take on the best Mustang DNA. I hope it keeps rolling.
millhouse
Simpsonville SC
2016 Ruby Red GT PP
Yeah, it's not getting smaller. There is a reason cars are bigger now than 20 years ago....and it's not just because of us fat Americans. Safety requirements and packaging pretty much dictate today's car sizes.
mikeyjobu
15 GT PP
A smaller, lighter car doesn't need as much tire -- but I think most S550's are lacking tire - I'm not suggesting it will be all the way down to SN95 proportions (but they had back seats too) -- I'm suggesting that it could split the difference in size -- the S500 is only slightly smaller than the S197, but it is smaller.
From Wikipedia:
Wheelbase 101.3 in (2,573 mm)[5] Length 1994-1998: 181.5 in (4,610 mm)[5]
1994-1998 Cobra: 182.5 in (4,636 mm)
1999–2004: 183.2 in (4,653 mm)
1999–2004 Cobra: 183.5 in (4,661 mm) Width 1994–98: 71.8 in (1,824 mm)
1999–2004: 73.1 in (1,857 mm) Height 1994–96 coupe: 52.9 in (1,344 mm) in
1997–98 coupe & Cobra convertible: 53.2 in (1,351 mm)
GT coupe, 1997–98 convertible & GT convertible: 53.4 in (1,356 mm) in
1994–96 GT convertible & Cobra: 53.3 in (1,354 mm)
1994–96 convertible: 53 in (1,346 mm)
1999–2004 coupe: 53.1 in (1,349 mm)
1999–2004 convertible & Cobra: 53.2 in (1,351 mm)
1999–2001 Cobra convertible: 53.3 in (1,354 mm)
Mach 1: 52.4 in (1,331 mm)
2002–04 SVT Cobra coupe: 52.5 in (1,334 mm)
2002–04 SVT Cobra convertible: 52.9 in (1,344 mm)
S550:
Wheelbase 107.1 in (2,720 mm) Length 188.3 in (4,784 mm) Width 75.4 in (1,916 mm) Height 54.4 in (1,381 mm) Curb weight 3,520–3,800 lb (1,600–1,720 kg)
I think they could find three inches off the rear overhang, keep the seats where they are, maybe still pull a half inch from the wheelbase, and up to an inch from the front overhangs then drop the car about a half inch by losing a little ground clearance -- keep the tracks front and rear where they are, and put nothing less than 255 wide tires on all trim levels, magnetic ride standard by the S650 mid-cycle refresh, keeping the car to about 3400 pounds with the techniques used on the F150...
millhouse
Simpsonville SC
2016 Ruby Red GT PP
From Wikipedia:
S550:
Again, not happening. There is a reason the camaro and mustang are very close in overall size. In order to have adequate crash protection for all occupants, the current sizes are not getting any smaller.
mikeyjobu
15 GT PP
We're only talking less than 6 inches of total length -- I'm sure they can find close to 3 inches somewhere. The wheelbase and tracks are needed for stability -- they shouldn't pull much there -- but they could pull an inch and a half from the rear overhang pretty easily -- it would sacrifice some trunk space, but it would still be practical.
millhouse
Simpsonville SC
2016 Ruby Red GT PP
That overhang is there for a reason....it's not all aesthetics. The crumple zones incorporate that overhang for occupant protection.
And no, sacrificing trunk space does not need to be done. These cars aren't Miatas for petes sake. The only way these cars are getting any smaller is if they completely eliminate the V8 engine.
mikeyjobu
15 GT PP
Sure -- and nobody wants to see the demise of the V8. As far as crumple zones -- how does aluminum used in the F150 compare to the soft steel used in a lot of the bodywork? Maybe I expect to much from the full F150-ization effect. The fuel economy standards are also going to go up, so the weight will have to come down. I hope we never see a Mustang based on the Focus platform...
Hack
Minneapolis
Mustang, Camaro
There's a ton of extra room in our cars. I hope they make them smaller and lighter as well.
Twin Turbo
Super Moderator
Moderator
England
Mustang '05 GT
As much as I lamented the demise of retro when Ford designed the S550, they made the right move in going modern, whilst still keeping an eye on the past.
This first one would be fantastic, if spun off the S197. It's looks a little like the Equus....and I could see this being done by the likes of the Ringbrothers or Mr Foose.....but it's not the direction Ford should take with S650. That car needs to appeal to a broader audience.
And that's where the second one wins for me. I think it has hints of the '71-'73 Mustang, especially with that full fastback....but with a thoroughly modern twist.
I love them both for different reasons :)
S650 Mustang 2021 MUSTANG (S650) - 7th Generation Mustang Confirmed S650 retro
S650 Mustang 2021 MUSTANG (S650) - 7th Generation Mustang Confirmed S650 Modern
SVT-DADDY
World's heaviest S550
CT
2015 GT Convertible
Why make the car smaller? Switch the Chassis to aluminum and throw on some ligter wheels.
Boom everyone is happy!
Honesty if the car was any smaller I'd buy a Corvette. The Mustang is meant to be a Grand toruing car, not a sports car.
