Christian/AWE
Gold Sponsor
Horsham PA
BMW X5 Msport, Swapped NA Miata, Mk7 GTI, Chevy 1500
All throttle. Presenting the AWE S-FLO Carbon Intake for the S650 Mustang GT & Dark Horse:
The S-FLO Carbon Intake for the S650 Mustang GT & Dark Horse is AWE’s clean-sheet answer to factory restriction, built to move more air, pull harder, and sound sharper, with an OEM+ aesthetic and dyno-proven power gains to match. Genuine 2x2 matte carbon and a sealed airbox keep the charge controlled while turning throttle input into real audible response. Engineered, tested, and validated in-house, S-FLO installs on factory mounting points, integrates like it belongs there, and delivers real performance with no tune required, backed by AWE’s Perfect Fitment Guarantee and No Check Engine Light Guarantee.
  • Massive filter upgrade: Dual air filters, massive 5.00” outlets, each with a 41% increase in surface area per filter over stock
  • AWE carbon tube has an oversized 4.25” outlet to allow for throttle body upgrades
  • Max gains of +15 hp and +15 lb-ft of torque at the wheels
  • S-FLO Filter is washable and oil-less
  • Intake box protects from heat while maximizing aggressive intake sound
  • Carbon boxes seal to the hood
  • Genuine 2x2 carbon construction, UV-stabilized resin and matte clear coat
  • No tune required
  • Utilizes stock mounting locations
  • Perfect integration with OEM inlet ducting, retains stock mounting locations
  • Designed, engineered, and tested in-house at AWE
  • Perfect fitment, guaranteed
  • AWE No Check Engine Light Guarantee
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_16
ALL THROTTLE.
The S-FLO Carbon Intake for the S650 Mustang GT & Dark Horse pairs genuine 2x2 carbon fiber construction with precision-engineered airflow to deliver real gains, sharper response, and a harder-edged induction note without sacrificing factory-like fitment or drivability.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_20
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_4
MASSIVE FILTER UPGRADE:
Dual AWE S-FLO Filters with massive 5.00” outlets deliver a 41% increase in surface area per filter over stock. Oil-less and washable by design, they’re built for maximum flow and easy maintenance.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_18
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_17
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_5
READY FOR THROTTLE BODY UPGRADES:
AWE’s carbon inlet tubes feature an oversized 4.25” outlet to support throttle body upgrades so the intake won’t be the limiting factor as power goals climb.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_21
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_8
CARBON THAT LOOKS OEM+:
A mirrored twin-box layout cleans up the entire engine bay, with UV-stabilized 2x2 carbon construction and a matte clear coat finish that looks intentional, not aftermarket. The airboxes seal to the hood, isolating the charge from engine bay heat.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_19
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_3
POWER TO THE PAVEMENT:
The S-FLO Carbon Intake delivers gains of up to +15 hp and +15 lb-ft of torque at the wheels on an otherwise stock vehicle. No tune required.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse S650_MUSTANG_GT_WHEEL_DYNO
INTEGRATED BY DESIGN:
S-FLO utilizes stock mounting locations and integrates cleanly with OEM inlet ducting for a pure bolt-on installation.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_23
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_6
THE FINE PRINT:
AWE’s Perfect Fitment Guarantee and No CEL Guarantee come standard.
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_13
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_15
S650 Mustang [Now Available] AWE S-FLO Carbon Intake for 5.0L S650 Mustang GT & Dark Horse 2660-15650_12
jboogie1289
Friendswood Texas, 77546
“ delivers real performance with no tune required”
Would like a bit more information on this please per your quote in the description.
Epiphany
Global
I like to disassemble things.
Absolutely gorgeous.
DevilDog
Northern Illinois
2024 Mustang GT on order
Christian/AWE
Christian/AWE
Gold Sponsor
Horsham PA
We will be able to return to and answer all of these in depth on launch day. For now, don't forget to sign up to be notified. Subscribing to this thread also works, as it will be updated into the product release when the time comes.
Can I drill and tap nitrous nozzles in the tubes? How thick are they?
This is carbon fiber, so you would be drilling it and sourcing some type of compatible fitting.
Are you going to offer just the CF tubes, and will they fit the OEM air boxes? TY!
We will be selling these as a complete system. 🛠 We will update this thread with all the details.
Stay tuned, on release we will include the dyno graph and more information on filter size/performance. 📈
this is dope & all but the open box design concerns me for heat soak
This is essentially an expertly engineered "isolated intake design" featuring a dynamic weather seal that compresses against the hood when closed. This effectively creates a fully enclosed airbox, isolating the filter from engine bay heat. More on this topic after release!
Christian/AWE
Christian/AWE
Gold Sponsor
Horsham PA
Are the filters dry or oiled?
Dry. More on the filters after release.
Open air boxes that requires a seal against the hood, not good.
You will find the quality, fit/finish, and function of our product to be in a league of its own. More details to come on launch day.
DeeDub SC
S650 Mustang GT, Audi Q5, 1993 Mustang
Sounds interesting, but suspicious as well! Will be fun to see how this develops. AWE is a good company, so hopefully, they will have some solid info on how this would upgrade our 5.0s.
Christian/AWE
Christian/AWE
Gold Sponsor
Horsham PA
Of course we will. See you all at launch day. :sunglasses: 💯
exm
Long Island, NY
Thanks, keep us posted
