Wheel Clearance Question
dblvenom
North Carolina
2025 Mustang GT Premium
Hoping someone has this setup. Seeking to install 19x10 Apex EC7 ET40 for a square setup on an PP non-magnaride GT. Installing Steeda Dual Rate springs and adjustable struts. Will I need a spacer for clearance?
Manual Ronnie
Atlanta, GA
ā€˜25 5.0, ā€˜19 Canyon 4X4, ā€˜11 Harley Dyna
I would not think think so. Im running square 19x10 Steeda +37 offset and lowered on FP track springs.
needforspeedirl
In Front of You
2024 Mustang RTR Spec 2
I run Apex ML-10RT
Here’s my setup
F: 19x10 et 40 275/35
R: 19x11 et 52 305/35
I’m running the RTR tactical suspension that came on my spec 2 RTR.
I did not like this look so I added a 30 mm spacer to the front and a 20 mm spacer in the rear. I now have a little poke at all 4 corners with no rubbing or scrubbing.
Apex Wheels
Gold Sponsor
Bay Area
Mustang
You won't need any spacers! Paired with a 275 or 285 would be a great fit. It's a direct bolt-on setup that should be nice and flush. A 285 gives a meaty look, while a 275 will be a little more reserved and hide under the fender better. You'll be good to lower the car as well.
Let me know if you have questions! Happy to help!
