USB Port in mirror
Paul's stable
Maple Ridge BC Canada
My Uniden R8 requires 11 to 16 volts to operate. I believe that USB port will only support 5V. I didn't even try it - I used a cable with the taps for the rain sensor (behind the cover behind the rear view mirror) that had the Uniden R8 plug @ the other end. Detector is mounted under the rear view mirror with a Blendmount.
Could you post some pictures. So did you splice into the wiper sensor? I'm not the best at wiring as I'm color blind. My Uniden r8 came with a phone type power plug so not sure where or how to get power from mirror as I used the USB plug for my dash cam.
Gr8ful
S.Carolina
2023 Santa Cruz, V-Strom 650
I have an older Escort and seems to function just fine. Alerts to automatic doors also. I never leave it on so I can't if it times out.
Stangerous
Stangerous
Space Coast, Florida
Hey guys, I’ve been running my dash cam and radar off the mirror usb using a splitter for almost a year now. Both work flawlessly with no issues.
Decible
2020 Ford Mustang GT PP1
How many usb ports does the Darkhorse premium have? I’ve only found 2. 1 behind the mirror and 1 in the lower center stack.
Farmer Fran
2024 GT Premium Vert
What Dash Cam - I am really wanting one, but want one that can see the front and somewhat out of the convertible rear window
Kitulu
United States
Are there not two in the lower center stack? My GT has a USB-A and a USB-C in the lower center stack.
Decible
Hmmm I’ll go look in a few, I don’t think so.
Alan Applegate
Roswell, NM
I think I mentioned this before, but.... I have a Rexing V1P with rear cam. This is the 5th one I've purchased from them for the various vehicles in the last 5 years or so. Never ever an issue with any of them. Oh! Mine is also powered from the mirrors USB Port (5 VDC).
Alex381
Did you end up buying one? I picked up a Garmin X310 and it works great off the mirror usb port.
Farmer Fran
Not yet. Still looking
yep, the standard for USB type A says the max voltage is 5V no matter what generation. only USB type C can deliver higher voltages, up to 48V
So what is the purpose of this port up in the location if it is only 5 V?
So a 5 volt port is powering two devices?
Do you know what their voltage requirements are?
