Steeda Stop the Hop Kit
jexsk
Louisville
‘24 Mustang GT, ‘22 F-150 Lariat
Looking at ordering the Steeda Stop the Hop street kit but before I did I wanted to see if anyone has already done this and their impressions. Noticed improvements under hard acceleration, chassis feel when cornering etc.
I just did the bushings and locators and it work’s excellent!
small but noteworthy difference of the IRS being more “tied in” to the car.
I should’ve done it the same time as springs.
tj@steeda
2015 Steeda Mustang
Yes - these are proven and you will be very happy with the results. Let me know if I can put you in contact with our build team support your purchase decision - happy to help!
TJ
jexsk
jexsk
Louisville
Thanks, I ended up ordering it. I’ll post back once I get it installed
tj@steeda
2015 Steeda Mustang
jexsk
jexsk
Louisville
Just got this installed and wow did this make a difference. Haven’t noticed hop on the pulls I’ve done and the front end stays straight as opposed to hunting for pedestrians lol Highly recommend and would definitely add to any future Mustangs.
Installation was straightforward with the exception of two things.
The two piece bushing on the rear was a real PITA. CJ Pony Parts had a good video on it and recommended lubing and using a screwdriver to help make the turn but it was still a pain.
Lastly on the driver side to remove the rear bolt it was right above the exhaust and I couldn’t get my wrench in there no matter which way extension I used. I finally ended up unbolting the exhaust mount near the tips so I could wiggle it out of the way.
tj@steeda
2015 Steeda Mustang
Thank you for the feedback!
Glad you were able to get everything installed :)
TJ
CT22
Austin
Ram1500
@Steeda Tech JohnC @SteedaTech @Steeda UK
I am about to install your Stop the Hope Starter kit and I cannot find PDF instructions anywhere on your site like other products.
Please attach those instructions here asap. I only have the lift available today to me. I can't believe it's not readily available on your webpage. Thanks!
I believe there is a video.
jexsk
jexsk
Louisville
[/QUOTE
So the instructions aren’t on the site for the kit but they are on there for each individual component in the kit. A little bit of a pain they’re not in one spot
CT22
Austin
Ram1500
Thank you! I found them individually. Good idea. Still can't believe they don't have wholistic ones for the kits.
tj@steeda
2015 Steeda Mustang
We have individual ones listed under each product page and installation videos on complete kit installations.
Best,
TJ
Easy700
Melbourne
S650
I installed this kit last week. The IRS subframe braces, the alignment bushings, the bushing support brackets and the vertical links. This is in a AU delivery GT Manual Fastback with Magnaride and the Brembos. Very happy, only one observation, the vertical links in the S650 appear to have been upgraded and look to be almost identical to the Steeda items and I wouldn't have bothered if It's realised, I would have just run with the stock links.
Yes, it appears that all S650s get the better vertical links... just add the bearing at the knuckle end...
