Schwerin
Philly
2019 Mustang BULLITT
I actually dont find it that bad.
DeluxeStang
Utah
Explorer
I said it earlier, but it seems like sketch monkey (the guy who created this render) produces very missed results.
Ace
Kia Proceed GT
He didn't even bother to change any bodylines or the hood, he just changed the frontend. The base design language of the frontend might be similiar, but overall this looks totally off.
BoostRabbitGT
'19 EcoBoost (101A)
Yeah he's nowhere near it really..
I think this rendering is okay despite how far away from reality it is (rear corners of the headlights look too far into the side of the car in my opinion), but it is good to know that the S650 won't be as mild a refresh as this latest take from SketchMonkey's was.
thePill
Camaro5's Most Wanted
Pittsburgh
S550
…the edginess may be somewhat correct but that’s where the similarities probably end. Maybe some “New Edge” design cues from the fenders back with a more ‘68-‘69 inspired front fascia. I have a feeling people will move to say “it’s an Aston Martin” like they use to say “it’s a Fusion” back in 2014. 🤣
9secondko
Irvine, ca
2003 cobra
Another giant grille that serves no purpose?
Come on.
It e mustang does not need this. Ford only opens up a small portion of it for actual cooling. The rest is blocked off.
would love to see for following function in the mustang again. Not some weird attempt at looking like the old car from the 60s.
As it is, the render is extremely well done, but the design Is a backward step from the current car. Hope this is not actual target.
LETHAL
From the D but in the NC
From the D to NC
Just traded my 18GT and plan on getting into a 24' when they come around. Not sure if this will get me back into one. It's not fugly though.
Deleted member 49342
Guest
If you have seen the show "Resident Alien", Harry's smile looks just like that.
showbbq
Houston
2018 Mustang GT
Not a huge fan. I'm hoping for a more aggressive look without it resembling a Camaro or an Infiniti sedan.
thePill
Pittsburgh
S550
This is where the Mustang is heading although, this particular CAD example may represent a slightly shorter wheelbase, say around 105 inches. The “Mule” that we have been “spying” is simply an S550 with inserts under the camouflage and has absolutely NOTHING to do with exterior design. Anything you see in camo might be testing drivetrain but there is absolutely nothing done to the panels or fascia.
The GT and “ST” (Ecoboost placeholder) will still host the standard 107 inch wheelbase. However, most of the S650’s exterior can fit comfortably within the S550’s body with maybe an exception of some fender flare and longer front overhang. The S650 will look like an S550 with really low body fat.
I believe the eMustang will continue to be available on a modified Mach-E platform at 115 inches. That said, don’t discount the possibility that Ford will look at the 107 inch wheelbase for eMustang’s as well as any short version of the S650 as well.
The S650 will make the S550 feel like an S197 when the 550’s came out. Perhaps the gap between the 550 and 650 won’t be as wide as the S197 and S550 but the looks alone will make the pre-2024 Mustang’s look very dated.
~thePill
S650 Mustang S650 Mustang rendered by Sketch Monkey 6F18D77E-3785-4A3B-9BFE-524A8319B50B
S650 Mustang S650 Mustang rendered by Sketch Monkey FACEC3CF-6DBB-4FC1-9667-B695D30E577B
S650 Mustang S650 Mustang rendered by Sketch Monkey FE9C24FD-F228-4FCE-87B8-A3615473065C
thePill
Pittsburgh
S550
…nearly identical greenhouses but due to a slightly flatter rear overhang and a slightly extended front fascia, it will appear as if the cockpit moved back. I believe this is the most likely direction and I really like it.
S650 Mustang S650 Mustang rendered by Sketch Monkey 1A02F4C8-A4AD-4B2F-A6B9-80FE5BE8DF54
thePill
Pittsburgh
S550
The GTE is probably an electric concept on a 107 inch wheelbase. This study was conducted in 2018-‘19 as far as I know but I expect Kemal’s original vision will continue to be realized. The Mach-E came soon after.
I know that Ford intends on pushing some of the Mustang models into “Sports Car” territory and that means the exterior design is only headed one way. I do believe that this design was decided on before the 2015 GT350 was unveiled and the S650 was co-developed with the S550.
S650 Mustang S650 Mustang rendered by Sketch Monkey D6CB365D-16CD-4059-9731-B5CE1922CF3B
S650 Mustang S650 Mustang rendered by Sketch Monkey 62237A31-BF77-4B62-8CF6-085163AF24A2
S650 Mustang S650 Mustang rendered by Sketch Monkey DBE7E758-9C71-4DA6-9EA6-EDD4D8F7DD99
S650 Mustang S650 Mustang rendered by Sketch Monkey 499083BC-9470-4F77-901A-FC07CEDD4A65
S650 Mustang S650 Mustang rendered by Sketch Monkey 7B455D37-020E-4806-A078-F10A6BEDEF6D
S650 Mustang S650 Mustang rendered by Sketch Monkey 458EF35C-5F5B-4023-A625-6F9A172E34B6
S650 Mustang S650 Mustang rendered by Sketch Monkey 504C53B1-8D3B-473B-9C57-9E23AD54F6EF
S650 Mustang S650 Mustang rendered by Sketch Monkey 1C532664-2A59-482D-9CDE-F836512DC3B0
S650 Mustang S650 Mustang rendered by Sketch Monkey 4FD2E8D6-B335-4AE3-B16A-AFE1B24081C2
S650 Mustang S650 Mustang rendered by Sketch Monkey 81CF8354-C181-4C99-AE3C-AA0C502E7FB6
