shogun32
Northern VA
2019 GT+PP, SS+1LE, 2020 F150
What turned you off of it?
no stick - specificallyt the DCT shift-strategy kept bogging the motor down to 1500 RPM. It was less obnoxious about it in SPort/Track mode but still pointless and annoying. A shift/clutch-by-wire stick would go SO FAR to fix this!
The paddles were incredibly cheap feeling and had massive travel. They should be short-throw micro-contact switches.
cabin was obnoxiously "driver-focused" and in so doing the view to the auxiliary screen was shrouded by not only my hands but also the steering wheel. When you have to move your head off-axis to see the left 3rd of the screen there is something wrong with design.
steering wheel too small. the arms/shoulders expect a certain 'splay' angle and it was too narrow. But not horribly so. The grip surface contour was pretty good though.
seat is very low, lower than my Camaro. I realize it goes with the territory...
The dash surface was incredibly deep and front glass obscenely 'out there'. Pull it back 6 inches, give it a more vertical angle and pull the eye-brow back 2" an higher by 2" and it would have been vastly better. Classic case of someone losing the plot in the name of a drawing that looked "cool" on paper. Had to crane my head to see the traffic light. Not as bad as in the Camaro FWIW. Does GM not employ people over the height of 5 ft 6?
rear view cluttered with all kinds of reflections and glare from that engine cover etc. Should have just made it a camera shot from an un-obstructed vantage point.
Did some S-bends at a decent clip. Tracks true enough but doesn't give the feeling it's actually going to finish the arc. I don't like cars you have to trust blindly. It should give you feedback that gives confidence that it IS up to the task.
designatedrhythm
North Carolina
Ford Mustang Ecoboost/Chevy Silverado 1500 RST
The dash surface was incredibly long and front glass obscenely 'out there'. Pull it back 6 inches, give it a more vertical angle and pull the eye-brow back 2" an higher by 2" and it would have been vastly better. Classic case of someone losing the plot in the name of a drawing that looked "cool" on paper. Had to crane my head to see the traffic light. Not as bad as in the Camaro FWIW. Does GM not employ people over the height of 5 ft 6?
Did some S-bends at a decent clip. Tracks true enough but doesn't give the feeling it's actually going to finish the arc. I don't like cars you have to trust blindly. It should give you feedback that gives confidence it IS up to the task.
Great detailed response. Maybe I'll keep lusting after the new mustang and M2 then....
Zcarmenb28
Idaho
21 Camaro ZL1, 22 Supra 3.0
The S650 is just a S550 with new sheetmetal and dash. It’s a poor attempt at a new Gen.
The front and rear overhangs are entirely too long. They look absolutely silly, that front overhang is like a front wheel drive proportion, I think it just looks awful. And thanks to the OP for pointing out the very long trunk lid deck, that thing is ridiculous.
I agree with the others who are saying that all the hard points and structural metal are probably identical between S550 and S650. The roofline is the same, don’t be fooled.
To those comparing this to the new edge Mustang, that was the same generation just a redesign. Ford is claiming this is a new generation, however, in reality it’s just a redesign of sheet metal and interior dash.
DeluxeStang
Utah
Explorer
Wait 'till you see "new" generations of the 911. That will make the s650 seem like a radical departure by comparison.
Charlemagne
Czech Republic
2021 Mustang Mach 1 Velocity Blue M3440
Gotta agree here, why should new generation look drastically different? They got it right with S550 so they just tweaked it a bit to make it different enough (even too much for me, haha). 911 is nice example that when it's great, keep it that way.
Ace
Kia Proceed GT
I don't get those points. Of course the dct in tour mode shifts to the highest gear possible for fuel economy. You can overwrite it anytime, go to a sportier mode that holds higher rpms or just go into the manual mode for complete freedom. Honestly the C8 DCT is the best programmed automatic I have driven, it reacts instantly to the throttle, so a kickdown always results in fast low gears with punch.
Compared to Fords 10 speed in the Mustang, even if you kick down in sportier modes it always shifts down in 2-3 steps and what feels like a whole second before you have the punch you wanted. And with 10 gears it's just horrible to shift manually, you're constantly clicking. Even the GT500s 7-speed has the problem that you wait for the computer to get what you want to do with a kickdown.
And the C8 has real metal paddles compared to Mustangs or Camaros cheap plastic ones.
But comparing Mustang and C8 is overall pretty useless, totally different cars with totally different target audiences. If you are looking for a pure sportscar you won't buy a Mustang, if you want a Grand Tourer for daily driving you won't buy a C8.
Baldilocks
Delaware
My old high school buddy has a 1LT 2021 C8 Stingray. Every time I drive it I want one more and more. (shrug). I think everyone is different when it comes to what they perceive and what they like. For instance, the paddle shifters are aluminum and much better than anything the A10 Mustang has (or Camaro for that matter).
I'm 6'2" and have plenty of headroom/visability, etc. Since his is a convertible, it has the rear-view mirror camera which works quite well.
The biggest thing that impresses me is the build quality and the material on the interior. Makes my Mustang feel like a 90s interior by comparison.
Still waiting to see how the interior of the S650 turns out...
  • Like
Reactions: Ace
shogun32
Northern VA
try a Blackwing. Interior fit+finish is right on. The stick shift has the proper amount of notchiness to it too. Unlike the Camaro that preceded it.
shogun32
Northern VA
sure, but I'm not comparing C8 against those, rather Audi, BMW and even Ferrari and McLaren. The issue isn't that they are now AL instead of plastic, it's the tacky feel to them.
I'll give you that. But my brain knew that it wanted that gear a second ago and I would have done the shift before I entered the curve and not while in it. Sure that's what paddles are for, but if I have to resort to paddles constantly, give me the damn stick!
I don't know why Ford/GM don't implement the high-gear lockout feature the F-150's A10 has. It's quite useful and would be a huge benefit in the Mustang/Camaro.
OppoLock
RWD Addict
FL
2015 GT, 2020 GT350
Agreed on all points.
On the topic of paddles, an ideal paddle shift experience would involve the use of some kind of cool-to-the-touch alloy, have a positive actuation with lengthy travel (eg C8, any PDK, even the Raptor and GT500, older M cars, etc), and be as close to instantaneously reacting to input as possible.
The plastic buttons in the A10 are like anything you’d find in a non-halo VAG product, unsatisfying and inexpensive feeling, both in their tactility and the nature of their actuation.
Twin Turbo
Super Moderator
Moderator
England
Mustang '05 GT
I'm sure I read somewhere that Dark Horse gets the aluminum paddles from the GT500. I hope they are an easy retro-fit for 10-speed equipped S650s.
Dub347sbf
2024 Mustang Dark Horse
I read it too. Possibly the same blue color as the manual shift knob or something like that was said.
IFFV68
I went on Saturday and my reaction was the same as yours. Some cars look significantly different/better in person, but this looks exactly the same in photos as it does in person. Everything I didn't like about it in pictures still bothered me in person: the mix of gloss black and matte black on the front fascia and grilles, the gloss black of the upper grille that extends down onto the bumper (I really hate that look), the cheap looking hood vent, and the odd looking rear end. The car seems to have even lost character on the sides because everything is just kind of flattened out.
FWIW, I rarely even saw anyone else checking out the car. I posted in another thread how I watched a guy walk past it and remark "why is that on the stand? Oh, it's a '24" and he just kept on walking.
Please try to remember the Camaro & the Dodge Challenger are EXTINCT after the 2024 model year.
Chevy and Dodge loyalists will be somewhat in a FOG for the 2024 model year.
There will be more negative comments than positive comments on the new 2024 Mustang..
IT would probably be the same if Ford made a 4-Door Mustang. Or dropped the Mustang and came out with a FAKE ELECTRIC MUSTANG &
Calling it a MUSCLE CAR.
I feel your pain.
Not really,
