S650 Aftermarket Sound System
ichie123
Mississippi
ordered 24 Gt premium
AudioDesign in Jacksonville FL is around the corner from my house. They scanned my trunk with a 3D scanner. There is a little difference in the '24 with the fuel line, and why there is a little space in the original design pictured in his car. I also got the amp rack that they sell, and it fits in the '24. I will post in the next week when I get the subs in. I have Sundown SML 10" that are going into the new boxes. I wanted to save the trunk space and the passthrough to the back seats.
https://store.audiodesignscg.com/
You ever get that done? Interested in seeing the new design fit
Drewmandoo
2024 Mustang DH
Oh that big boy, here ya go!
One thing to note, I wouldn't use PLA for it if you are in any southern area with hot temps, it will deform and make it very difficult to remove the spare tire screw.
Ben Beard
Where/ how is everyone mounting their bass knob? I am looking for a mounting solution without drilling any holes in the plastic of the dash.
Drewmandoo
2024 Mustang DH
I have mine routed to the cubby arm rest. I fished the wires under the center console with the tweeter wires. Popped a small hole for the cable, and double sided tape sticks it to the plastic. Removable with some patience too.
ichie123
Mississippi
I popped my cigerette lighter plug out and my knob fits where it was. I don’t use anything that requires that plug
Ragstrom
2025 GT Carbonized Gray
Was anybody able to confirm the speaker wiring in the rear speakers?
I'm assuming it's the two twisted pairs:
Blue/White + Yellow/Green
Brown/Blue + Grey/Brown
Thought I'd ask before tapping them and testing with a multi meter.
Edit:
I went ahead and installed my sub. In case anyone else comes across this in the future, here's my results:
Blue-White = Left speaker +
Yellow-Green = Left speaker -
Brown-Blue = Right speaker +
Gray-Brown = Right speaker -
I used a 9V battery to try and determine the polarity, so if this is incorrect feel free to correct me. Either way, that is how I have it wired into my line output converter and into the amp. Sub seems to be working without issue.
I just did mine and have the same wiring as this. 2025 GT Coupe 9 speaker non B&O, built March 2025. I pulled the rear shelf off to check exactly what was running to the speakers.
Wanted to share in case any one else is adding a subwoofer.
slater
San Diego
xx
Seems like nobody mentioned it here...
You can use forescan to turn off the fake noise, ANC, & flatten the EQ Curve.
I did it on my 25 F150
SoundsGood Stereo was very helpful with this, as im scared of forescan but I did it.
Im guessing you have to go that route if I buy a base system that doesnt have an amp.
My understanding the PAC controller wont work if its not the amped system..
Sucks the OP never mentioned where he sourced the box, seems like he fell off shortly after making the post,
