Rev Matching
tastetickles
Borneo
Focus RS, Jeep Gladiator, Mustang GT
Who's seen the new Ferrari Dodici Cilindre manuale?
An 8 speed DCT, with a 6 speed gated shift and "clutch pedal" for manual shifting.
It only uses the first 6 gears for manual shifting as 7th and 8th are overdrive gears.
They've even set it up so that you can stall it if you are fumble footed.
If it actually feels like a manual, this is the end to manual or auto threads.
Are you listening Mr Ford?
didn’t koenigsegg release one on CC850 few years ago a nine speed that can switch to manual mode that weighs 90kg.
SweptVolume
United Kingdom
2024 GT Convertible, Yellow Splash, 6MT, Mag Ride, Red Callipers
I turned it off immediately and haven't turned it back on. I regularly rev match using my right foot, but, as you say, that's sometimes a bit obnoxious, and on those occasions I can change down gently and quietly.
The pedal arrangement (on RHD at least) isn't great for proper heel and toe downshifts, which is a shame, so if I was really on it (on a track, for example), I'd probably turn it back on to protect the transmission.
tastetickles
Borneo
Indeed the pedal arrangement sucked on the RHD and its slightly canted to the right. I got some pedals from UltimatePedals but haven't install them yet.
Yep. Not sure how well an 8 speed manual would work. It would have to have effective interlocks to prevent misshifting on a gate that close together.
PS. Speaking of rev matching, we went to look at an Abarth 595 with the selespeed/duologic robotised manual. That is an interesting system as it requires some throttle finesse in auto mode to do smooth shifts, much like a manual. In manual mode you just use the paddles for near instant shifts with rev matching.
To my surprise Tracey really liked it for that involvement. She's a special girlšŸ˜
Terminus
Alaska
25 400A 6-Speed Black/Black Nite Pony Performance Exhaust
I turned off the rev matching first thing when I got the car. I learned on stick shifts in the early 70s. IMO rev matching is horse pucky! šŸŽ
TSimo
2026 GT premium convertible; 2022 Porsche Cayenne S; 2020 Mercedes S560 4Matic
I love it! I like the sound & 90% of the cars around me have no idea what rev match is due to no one drives a manual transmission car any more
d4rkg04t
United States
Whipple Dark Horse w/ MANual
Men still do.
John S
Novi, Michigan
2022 Mustang Mach 1
I learned to shift on a Super T-10 with a mechanically actuated L-88 clutch and the muscle memory never fades. As much as I prefer my own rev matching and occasional double-clutching, Ford's auto rev matching is quicker than my footwork so I leave it enabled. I can still do my own rev-matching and double clutching with it enabled but if I'm "off" it's a reliable back-up.
GooberDH
2024 Mustang Dark Horse
I've been daily driving a stick for about a decade now. Drive by wire throttle is too inconsistent for me. I want to go from 6th to 4th, I give gas pedal a sharp push about 50% of its travel, revs increase by 500 šŸ–•šŸ–•šŸ–•. I want to go from 4th to 3rd, I just need like 500rpm increase, a 1-2in jab should do it. Revs increase by 1500šŸ–•šŸ–•šŸ–•. First thing I did when I was handed the keys to my Dark Horse was enable auto rev match and it's been enabled since.
GrabberB
Many full on race cars with professional drivers behind the wheel utilize a form of rev. match. How its managed varies to some degree... the end result is basically the same.
The development of computerized rev. matching began in professional racing not in production cars such as the Mustang and many others. The implementation of rev. matching in full on race cars was never intended to be a "training wheel" for rookies.
If rev-match only applies to downshifting what’s the overall impact on engine braking?
GrabberB
The amount of time rev. matching impacts engine braking (to zero) can vary from tenths of a second (driver) down to milliseconds when computer controlled including some professional drivers i.e., Ricky Rudd (Former NASCAR driver where computer rev. match will never be allowed). The only difference between rev. matching downshifts and non rev matching downshifts is the momentary position of the throttle body butterfly valve. The amount of time of the throttle blip occurs is very short (butterfly valve open in throttle body). During that brief time no engine braking from closed vacuum occurs. Engine braking will be the same in either scenario (rev match or not) when the clutch is reengaged with zero throttle applied.
There is no logical reason to not rev. match manual or computer controlled.
Edit to add what I forgot - With a smile :like: - Your question implies knowledge of how engine braking is affected during rev matching downshifts. Without knowledge one would likely not know to ask the question. Test?
šŸ‘šŸ» If the "blip" expires before the drivetrain connects, the entire purpose of the rev-match is defeated.
JPGC_S650
SC
I leave it on with my 2024. I've had 10 Mustangs over the years and for the ones that were manual transmissions, most were cable clutch and throttle. With the electronic throttle, even with the tune optimizing throttle response, I just can't get used to the slight delay/ pedal travel to be consistent like I would prefer for manual rev matching. Lol, I may be showing my age a bit but it is what it is.
