Order Error?
krisk
I just received my VIN this morning, and upon logging in to check the status online, the accessories show “Black with White Logo Brake Calipers.” My order is supposed to have red calipers. I’ve reached out to my dealer and they are checking into it. In the mean time, here is what I’m trying to find out:
1. Is it possible the order with Ford actually has the red calipers, but the online status is just incorrect?
2. If the build was entered by the dealer with the wrong calipers, is it possible to change the caliper color after the VIN has been assigned? If it’s possible to change, does this affect the build week?
Always good to double-check with the dealer. But yes, I'd go with #1.
While monitoring my build in '22, I experienced something similar. I logged in at some point and it was much like Ford's configurator: riddled with errors.
I remember one option was not listed. Actually, several. One item was listed, twice. That kind of thing.
I'd definitely go by dealer feedback and in-hand order before trusting the summary page on-line.
IDK about #2. I was always told once the VIN was cut, the order was locked. But others here have said they've been able to change at least some things, after VIN publication.
krisk
krisk
Thanks. The errors with the builder make me think it could just be an error with their status system. Hopefully that is the case.
Back2Gas
Mine also says Black with White Logo even though I ordered the red
krisk
krisk
Thank you. That makes me feel better about it just being an error in Ford’s system.
Jrws1014
North Carolina
I can’t even get the tracker to load or recognize my VIN/order number, so consider yourself lucky you can get that far lol
93-Oct Mayne
VA
Mine accurately reflects blue with white logo calipers in the tracker. I'd make sure the dealer entered it correctly.
marcekb
I had the same problem. I'm pretty sure the tracker is correct. My dealer acknowledged they entered it wrong and fixed the order after I had the VIN, and the tracker now shows it correctly. No other change to my scheduling or VIN happened.
Rick Deppe
Fusion
Even if your dealership ordered it wrong, it can be charged, you change whatever until it goes into production without pushing your production back. Unless there is restance on whatever you want to change.
krisk
krisk
Thanks for the replies. I got a response from the dealer and they confirmed it was an error on their part when inputting the order. They said they could not modify the order yet, but should be able to by Friday or Monday. Thanks for the replies.
Arlencito
Miami
2024 Mustang Gt
when i ordered my i did it with red calipers but was shipped with black and i did not check the online options.
Similar threads
