OPTIMA battery installed!
timd38
Hudson WI
Put a new OPTIMA DH6 in my Dark Horse today. Rated at 800 CCA, tested at an unbelievable 1,229 CCA!
S650 Mustang OPTIMA battery installed! 1714425635999-p5
S650 Mustang OPTIMA battery installed! IMG_5448
Be sure to reset the BMS (battery management system)
I have not tried this in the DH yet, but in my 2021 F150:
  • Ignition ON, Engine OFF
  • Headlights on
  • Note the solid battery icon in the speedo display
  • Flash the high beams five times in a row
  • Press and release the brake pedal 3 times
  • Wait approximately 10 seconds while watching the battery icon in the speedo display - it should flash three times, then go back solid.
  • Turn the ignition off.
If you see the battery icon flash 3 times as described above, you have reset your BMS.
You should do this after replacing a battery OR after a DEEP charge in the event you let your battery get low.
JAL
Gatineau Hills, QC
2019 Mustang GT
It's really nice, but I don't understand why you changed the battery now? Is it for weight savings?
timd38
timd38
Hudson WI
  • Headlights on
I have a tool for doing that.
I retired from the company 10 years ago, so they asked me to do an install. I was the Sales Director when I retired.
Reactions: JAL
The high beam/brake method is 100% tool less.
The ‘sleep’ method is also tool less 😁
It is. But asking people to not touch their Mustang for > 8.0 hours can be a challenge!
jboogie1289
Friendswood Texas, 77546
jboogie1289
