Battery Management
samson
How come you guys are so worried about your voltage, and monitoring it?
Just drive the car every couple of days and it charges it self.
I don’t understand why the hassle of manually charging it and constantly monitoring….
Nobody wants to risk their car dying on them. And with the electrical/battery issues that have been reported so far on the S650 we all got a little spooked.
I do think topping the battery off when you first get it is a good idea. There's no telling how long these batteries have been sitting before you take delivery. Seems like a lot of them are showing up with a low charge that doesn't seem to get charged up on the first drive for some reason.
YamenGT650
Dubai, UAE
Mustang GT 2024 PP
Makes sense for a long parked car… I’ve always been bad at understanding electricity, so i don’t claim to know what’s best.
Am curious since you mentioned topping it off the first time… I took the car for a 400 mile road trip on the 2nd day i got it, would that be enough to fully charge it? Instead of hooking it up to a wall charger?
samson
Yes that should be way more than enough to top it off. However, when I picked my car up I drove it about 70 miles home and the voltage reading were <13V the whole way. Then down to 12 the next day. Since I topped it off it seems to be at 14.5 - 15 while driving and 12.5-13 resting which appears correct. It's almost like it needed to be "trained" the first day with the charger. It's like it gets accustomed to not running and lowers the capacity and charge. Other folks here have a much better understanding of the BMS than I do. But that was my experience. All has been perfect since the charge.
sdsteele2
Tennessee
24 Mustang GT
What is the difference "electrically" if the car is locked vs. not locked?
When the car is shut off and locked, after a period of time it goes into a “deep sleep”. If the car is unlocked many of the subsystems stay in a standby state. When you lock it, you’re telling the car that it can power down more stuff when it wants to.
Side note, one of the ways to reset the battery management system baseline is to lock the car and leave it alone for something like 8 hours.
DCS
DCS
Ocala, FL
Side note, one of the ways to reset the battery management system baseline is to lock the car and leave it alone for something like 8 house.
Good to know. I have been trying to get a consistent parasitic current reading (car shut off, but not locked) with an inductive current meter. However, the three times I have done this I have seen three different readings - 400mA, 300mA, 100mA. Readings were taken from the negative lead from the battery - perhaps 30 minutes to an hour after shutdown. The clamp on my meter is too small to go around the positive lead.
Question: will I be able to lock the car with the hood open?
JPGC_S650
SC
I said the same thing at first since my Mustang is my daily driver and I drive 90% of the time locally, so no need to charge or worry about charging it. However; I understand as I do the same thing with my motorcycle as it is a weekend toy for me.
RLE55
38.9967° N, -84.6310° W
A bit surprising not to drive it for 16-18 weeks, unless you’re like stuck in a snow packed neighborhood…
Exactly. Once the temps go below 45 on a constant basis, its hibernation time and that goes for the white stuff too. It's a summer car.
sdsteele2
Tennessee
24 Mustang GT
I think you can lock the car but I don’t know what happens if the hood latch sensor sees the hood open. I have never tried it.
DCS
DCS
Ocala, FL
Just an update:
I have been doing mostly around town driving. I barely get out of 4th. 420 miles total after 1 month o driving. I decided to put the Noco 5 amp charger/maintainer on the battery to see how long it took to get to "Green". It took a lot longer than I thought! I'd say about 5 hours. It spent a long time, ~2 hours, on the first red indicator.
Good news is that I have not had any software glitches.
samson
Just an update:
I just started her up for the first time in a couple days. Right on 15.0V while running. Seems like ever since I did that initial top off the battery has looked perfect.
