MustangNoob
CA
Oil analysis of my second coyote engine. Numbers on the table are more accurate form the ones I provide to blackstone. Oil has always been full synthetic.
When engine got installed I requested to add full synthetic motorcraft. Then in every oil change I used full synthetic Mobil 1 5w-30. Oil analysis in the first and third changes + TBN .
S650 Mustang Oil analysis from Blackstone 1781157114973-gn
S650 Mustang Oil analysis from Blackstone OilAnalysis
S650 Mustang Oil analysis from Blackstone tempImagehVgQ7f
BimmerDriver
RDU, NC
Who spelled mileage wrong twice, differently each time? LOL
I was going to do the oil analysis on my car, but then I thought, what would I do with the results?
In other words, if the results were bad, what could I do about it? It is to laugh if you think Ford would take action. They'll wait until the engine stops working and then replace it.
Not trying to harsh on the OP, I'm honestly curious what anyone would do if they had bad results other than perhaps water or coolant indicating a head gasket issue.
Alan Applegate
Roswell, NM
I wonder that too. I'd bet most drivers only know something is amiss when their engine just quits or catastrophically goes up in smoke! I'd also bet some engines go boom on purpose for whatever reason. Say, buyers remorse? I even wonder how many average daily drivers have their oil analyzed? I suspect I would if I owned a GM V8!
BrownsReds
Yeah, I'd question the validity of those results if they can't even spell correctly.
I'm guessing that Excel screenshot is from the OP
I'd be running the $15/jug semi-synthetic for the first couple break-in changes, it's only 2,500 miles. Then run 'good' oil for the first 'regular' interval change
That said what else do you expect for a new motor...I guess it doesn't hurt to know the engine is in good shape. But at $50/test or whatever....
MustangNoob
MustangNoob
CA
My fat fingers spelled the mileage wrong. As for the results, if they were bad, I'm pretty sure Ford couldn't do anything unless there was coolant in the oil and you'd see the coolant level drop over time. That's what happened with my old engine. As for the other numbers, if they were bad, I'd just drive it hard until the engine lets go and put a new one under warranty.
mmff88gt
NW Ohio
2019 Mustang GT Convertible
I got several analyses in a row from Blackstone on my first few oil changes. Although you can't do much about problems that might show up, the analyses showed how the additives were holding up and how long the oil could really go between changes. I've always used Motorcraft full synthetic -- initially 5w-20, then 5w-30. The Blackstone reports were showing that I could go up to 10,000 miles. I still change at around 7,000 to maintain a good cushion, but with oil changes involving 10 quarts of full synthetic, it's worthwhile not to send good oil down the drain.
MustangNoob
MustangNoob
CA
that
Probably peice of mind since he had the engine replaced IIRC.
I think getting an analysis done can be a good idea. I wouldn't do it on a regular basis, like truckies do though. Detecting fuel dilution early is one example.
Also, if you find high levels of bearing material, it might save engine goes boom.
Hack
Minneapolis
a Mustang and some other stuff
I don't do oil analysis either. I just change my oil regularly. I expect a catastrophic failure to be more likely for my engine vs. simple wear. If my engine gradually wears out in the next 20 years, I will feel lucky.
That is what I don't like about running an analysis is that people use it to justify not changing the oil. I disagree with extending oil change intervals. I think it's the worst thing you can do for your engine as far as wear goes.
Especially modern engines with hydraulic systems inside them like variable timing on the camshafts. Sludge will slow or stop those mechanical systems from working over time. Sludge is the buildup that doesn't come out when you change the oil and it doesn't show up in an oil analysis, because it's still inside your engine.
jcmana52
2024 Mustang GT 5.0 Base
Regular oil changes with quality oil; catch can to minimize PCV blow by. Next, MMR oil cooler.
Im a little surprised by the push back. There's nothing wrong with getting an oil analysis. Its not expensive and provides good data under certian scenarios.
I dont feel the need to do it on a new car. But they are essential in certian used car markets. I just had one done on my Porsche. Its great data to have when buying used or going to sell.
