Oil advice for a supercharged 2026 or 27 Dark Horse?
TX-TBeau
Round Rock, TX
2025 GT 5.0 6MT, 2018 Accord 1.5T 6MT, 2018 WRX 2.0T 6MT, RAM 1500 5.7 Hemi
I am sure there are lots of passionate opinions on oil, please share your thoughts, I will take it all as useful information. I already have a 2025 GT 6MT that I really enjoy driving. 400A, active exhaust, not performance package. I use PUP 5W30 at 400, 1200, and 3000 miles, now going 2500-3000 between changes. I just ordered a 2026 DH Premium with dealer installed whipple stage 1, performance package, regular ventilated seats ( in TX). I plan to take possession (when it comes in), drive it through break-in to 1500 miles before turning it over for the whipple installation. What oil should I use? Amsoil 5w50 Signature? Mobil 1 5w50 Supercar? Thanks
Whatever you want. Won't matter that much, people aren't wrecking the bearings on whipple cars.
Motorcraft 5W50 is their recommended oil, I change every 3k
On that note it’s September almost and I only put 1k miles on so far this year, gotta take some trips this fall before winter
TX-TBeau
Round Rock, TX
Texas summers are brutal, but I don't miss the icy northeast where I grew up. Cars in Texas never have any corrosion and we rarely have ice on the roads. Thanks for the input.
Ninjak
Posting from the Shadows
The Shadows
I use Mobil 1 Supercar 5wx50.
GrabberB
Been using Royal purple xpr 5w-50
The oil you're using is top shelf in the right application. It contains elevated levels of ZDPP (i.e., Zinc over 4x that of Motorcraft full synthetic).
I highly recommend changing your oil sooner rather than later. Change now, and maybe 2 more in short duration to get that RP XRP oil out. Oils with high levels of zinc can and will damage emission system components and should not be used in a Coyote engine. It's not like it will destroy the engine. Long term will cause issues catalytic convertors likely the first to go. ZDDP (zinc) is sacrificial. Explaining the full process is a boring read so I'll condense to this. The byproduct of ZDDP will eventually fuse itself to the small pores in the cats and cats go bye bye.
I still own a 2000 Dodge 3500 (dually) with a 5.9 Cummins engine (Bought new in 2000) Resides in the garage next to my Mustang. Around 2010 - 2011 I caught the Hot Rod Diesel bug. I spent way to much money on that truck and it now has a highly modified 5.9 Cummins. Getting to the point. I ran high levels of boost (not extreme). To keep the valves from doing the huck a buck with the pistons I installed heavy duty valve springs. This increases the pressure of the tappets to camshaft lobes. I run very high levels of zinc to avoid "wiping" lobes on the camshaft.
My Dodge no emissions high boost high tappet to camshaft lobe pressure = me love zinc. This is were high zinc level oils belong.
Billycar11
i appreciate the concern i have read about this before and know it to be true.
but i dont think it will be that much worse unless im burning oil and i have had catch cans since day 1 and the passenger side one after 5k only had maybe 1/8th-1/6th full so it prevented all that oil from being burned
my other car i have been using this oil for 50,000 miles and no issues and that does not have a catch can i should probably put one on that
TX-TBeau
Round Rock, TX
Interesting points. Sounds like three choices so far, 5w50 for Amsoil, Mobil 1 Supercar, or Motorcraft.
GrabberB
Passing along some friendly advice. And you're correct an engine consuming oil is far more likely to see emission issues sooner.
Appears you've done you homework and understand the risk vs. reward.
ZXMustang
tooner
5w50 full synth is the only requirement. Change it often, its cheap insurance. Dont think too hard otherwise on this.
GrabberB
Driven Racing Oil is top shelf. Lake Speed Jr. is a smart guy and former key employee of Joe Gibbs Driven Racing Oil. I'd be interested in seeing hard data and extensive testing to back up his self endorsement claims.
DarkHorsePremium
CA, Bay Area
I watched an interesting video yesterday about base oil availability due to the war in the Middle East. Shell owns many of the oil production facilities in the Middle East. They also own Pennzoil. The change had to do with the base oil formulation. Made from natural gas versus made with natural gas. I am no expert on the subject. The refining changes have an effect on the viscosity index and the amount of impurities present in the oil like zinc and magnesium. In the video the guy used a mass spectrometer and several other testing methods to demonstrate the changes in the chemical makeup of the oils. He was kind of goofy but did present interesting information.
Last year there was a formulation change from API-SP to API-SQ. This was before the war so it looks like this change was a financial decision. The oils are now chemically different but still maintain very high ratings. The impurities present is also slightly elevated. There was a discussion about this earlier this year on the forums. I had just bought my Dark Horse and was deciding on the oil type I was going to use. I bought three cases and ended up getting the later formulation. The SQ variant. This is the one that has a marginally lower viscosity index and slightly higher levels of impurities.
I use motorcraft full synthetic 5w-30 in my Dark Horse. I don't track my car. My friends who do recommend 5-5w-50 on track days. This is not something I'll likely have to worry about.
When it comes to oil I do have 50 plus years of experience in one area. Change interval. Oil is the lifeblood of your lawn mower, chainsaw, motorcycle or car. Since a very young age, I adopted a change more frequently practice. Oil and filters are cheap insurance. This practice has never let me down. There are differences in the blends and formulations. In my opinion, changing more frequently is more important than the brand of oil you use.
Edit - I also 100% agree that a passenger side catch can is a good idea.
