I absolutely agree with you Fruitstang, that a good subwoofer with the proper frequency should not be locatable. But...The subwoofer setting in these cars has a very strong crossover frequency, making it sound more like a rear speaker than a true subwoofer any day. Pan the surround setting 100% to the rear sub...you hear everything...not just the low frequency.
That said....I come from the era of 6x9 speakers on the rear package shelf along with the front dash speakers. I always wanted to be surrounded by the sound.
I'm now used to 5.1 surround sound. I watch movies in surround sound.... I listen to music at home in 5.1 surround. Everything in my house has 5 speakers and a sub. The car has a surround sound selection. I like being surrounded by sound.
To me have the music just blast in my face...may as well be mono AM radio.
But I'm not going to argue personal preference, that's something else.
Just .02 cents agreeing with both. I’ve usually tried to get it set so when listening to ā€˜stereo’ perception is in the center of the head (subs are more felt than heard - hence non locatable - doesn’t mean location doesn’t matter means unable to readily identify where when in use) with the occasional predominant or emphasized interlude sound coming from an isolated direction.
Starship Enterprise
Starship Enterprise
MD
2025 Mustang GT Premium
agreed Zig.
My take is that this sub in our car has such a high crossover it just sounds like any of the other speakers. It's the most non-sub sounding sub I ever heard.
agreed Zig.
I agree. The factory sub has a mid-bass hump which drives me crazy as it muddies up the sound.
I'll be installing the SW10A-D4 - DD Audio later this week when it arrives. I also have the Pioneer replacement sitting on the shelf as I never got around to installing it. Life has a tendency to get in the way once in a while !
I asked one of the fancy calculators (ai) what it would take to make the b&o ā€˜you shook me’, ā€˜whole lotta love’ compliant, provided you are open to entertaining more than just the classics.
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_9999
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0001
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0002
But looks like even the machine tries to cover its bases by suggesting a swap.
(Applicable settings follow)
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0007
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0003
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0004
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0005
S650 Mustang My Adventures in Upgrading the Subwoofer and Center Speaker IMG_0006
71stang99
US
72 Mach 1, 2024 F350 Tremor, 2024 Mustang GT
Correct me if I'm wrong there is no subwoofer setting right? Oddly the AI response said nothing about cancelling or changing the Forscan settings for the fake engine noise. I still need to do that but have to buy a laptop. I'm not packing my desktop to the garage!
^ correction appended (phone fight currently underway - editing mobile jumping page ugh)
Starship Enterprise
Starship Enterprise
MD
Stevo: Swapping the sub takes less than 1/2 hour. 3 easy to see bolts and the whole box comes right out. Easy unclip at the back. You will kick yourself you didn't do it sooner. It sounds THAT much better. Install that DD, the Pioneer turned out to be a very poor choice for the stock sub.
Zig: for the most part, that's good stuff. But yeah friggin AI can screw up a summary and details that is frightening think we are supposed to rely on this crap?
I've tried Stereo mode and it feels like mono compared to surround...
Though I agree with balance placement. I put it right at the headrests center.
ATM I have full Treble and Bass with Midrange at 0. too low midrange sounds muffled and too high sounds like a transistor radio.
Yeah, apologies the attempt at including summarized details got funked.
Even with upgrades it’s a tweak of the setting here and an adjustment there, depending on both source, sound and intent.
glad to hear your upgrade, in the end, made the adjustment you were after.
Cobrakit
Southern Maryland
2019 Mustang GT PREMIUM PP1
Is this the speaker being referenced?
DD AUDIO SW10-D4 10" SUB WOOFER 600W DUAL 4-OHM
    Speaker Size (In):10
    Watts RMS:100 - 300
    Watts Peak:600
    Impedance:D2 / D4
    VCD (In):2
    Piston Diameter (In):8
    Fs (Hz):35
    Qms:11.107
    Qes:0.53
    Qts:0.506
    Vas:32.495
    dBSPL:86
    Xmech (MM):18
    Xmax (MM):8
    Frame OD (In):10.12
    Frame OD w/Gasket (In):10.25
    Mounting Diameter (In):9
    Mounting Depth (In):4.75
    Motor Diameter (In):9
    Motor Depth (In):1.7
    Magnet Weight (Oz):55
    Woofer Displacement (CuFt):0.03
    Sealed Enclosure (CuFt):0.5 - 1.0
    Ported Enclosure (CuFt):.75 - 1.25
SteveinKG
2025 Mustang GT Premium; 1990 Mazda RX-7
You guys are really missing the boat in not adding a LOC and amp. It's really simple and the results are night and day difference. I understand this thread is about a budget upgrade but.....
I have the PAC for the aftermarket amp. And it is a sweet little piece of equipment. Did you just add your amp (watts?) and retain the oem speakers? If so, I am just going to imagine the difference is substantial.
I had a 24 s650 w b&o, and replaced everything, etc. If i get another one, id really like to forego replacing all those speakers as well as what it takes to replace, especially those rear ones! The sub replacement is cake.
Starship Enterprise
Starship Enterprise
MD
    Watts RMS:100 - 300
    Watts Peak:600
    Impedance:D2 / D4
    VCD (In):2
    Fs (Hz):35
    Qms:11.107
    Qes:0.53
    Qts:0.506
    Vas:32.495
    dBSPL:86
    Xmech (MM):18
    Xmax (MM):8
    Frame OD (In):10.12
Yes that is it. The key is the RMS wattage and sensitivity which is comparable to the Hyfonics.
I bought the Hyfonics sub which I believe is comparable and also half the price. I'd have to hear the DD to compare for real of course.
IMO you can't go wrong with either.
Cobrakit
Southern Maryland
Hifonics ZG10D4
10" Zeus Gamma 600 Watts Dual 4-Ohms Car Audio Subwoofer
Key Features:
10" Dual 4 Ohm Zeus Gamma Car Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
Recommended power range: 100 - 300 RMS
Diameter: 10.08"
Mounting Depth: 4.96"
Cutout: 9"
Spade Style Terminals
Thermal Formed Polypropylene ZEUS symbol and unqiue 6 spoke molded cone creates a strong cone face
Ideal for medium and large ported enclosures
Huge motor assemblies
Multicoated aluminum formers
Heavy gauge, powder-coated, stamped steel basket provides a solid base for the motor system and moving parts
"Through the Frame Venting" with mesh grill
Sensitivity (1 watt/1 meter): 86dB
Package Dimension: 11.90 x 11.50 x 5.60 Inches
Package Weight: 11.9lbs / 190.4oz
System
Western Ma
2025 Mustang GT Convertible
I used a Wavetech Link2 LOC and upgraded the sub driver to a Hertz Mille MPS 250 S4. For the amp I ran an Audison SR 1.500. I left the remaining B&O speakers except the center channel. There aren't a lot of 8 ohm options for center channel (oe unit is 8 ohm) but someone here recommended a very cheap option on Amazon it was worth the price of admission x100! https://www.amazon.com/dp/B00Q3M9852?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1 I am extremely happy with this setup. And mine is a convertible and still, the bass is unreal and the clarity is super improved with the center replaced...
Starship Enterprise
Starship Enterprise
MD
Nice. upgrading the amp is the most effective thing to do. I just don't want to dig that deep....lol
Mustang60th!
2025 Mustang GT 60th Anniversary
A subwoofer is, due to the frequency range it should play, supposed to be not locatable, that's why also home hifi subwoofers can be placed away from the main speakers.
If you clearly "hear" more music from the back, then it will rather be coming from the rear speakers which now sound from outside and inside the trunk with your seat folded down.
Also note that music typically shall come from the front rather than the rear, as most people in concerts face the stage rather than the people behind them :)
If you enjoy it more from behind (no pun intended), that's fine of course, but not what a good music system is designed for :)
I agree 100%. My sound locates just out over the front hood, yes, like a concert. Set the stereo to center in the car and the d
agreed Zig.
Yesterday I installed the DD SW10A-D4 drop-in replacement subwoofer installed in my S650 Mustang GT with the factory B&O system, and the difference is absolutely night and day.
The stock subwoofer was the weakest part of the system. The low-end bass was almost nonexistent, and many of the deeper frequencies were completely missing. After installing the DD SW10A-D4, the system finally delivers the lows that should have been there from the factory. Bass is deeper, fuller, cleaner, and much more noticeable without overpowering the rest of the music.
Installation was straightforward and took about an hour using the factory B&O amplifier. No complicated modifications required—just a true drop-in upgrade that works exactly as hoped for.
If you're disappointed with the factory subwoofer in your S650 Mustang, this is the upgrade you've been looking for. The improvement is drastic, the installation is easy, and the value is outstanding. I can't recommend the DD SW10A-D4 enough. $109
Don't forget to add polyfill and definitely get the $10 wire harness to avoid cutting factory wires. Could not be easier!!!
Yes, it does sound a little louder, but not much. The music is a lot clearer, not nearly as muddy, and there's a little more bass.
I purchased the 8ohm Dayton as well. Concerned with sound stage difference and over heating amp over time dropping the 8ohm to a 4ohm speaker. Not recommended.
