Forscan for beginners?
She’s gorgeous. Appears the fender liner hole issue is resolved. Ordering the black patches for the ugly visor airbag warning sticker.
Are the fender holes covered with patches or is it a new fender liner?
72Skiddoo
Down State Illinois
2025 Mustang Ecoboost Premium Convertible
A
wide angle ground up drivers side. It’s attached in the center but the seam in the left puckers a bit. Looks like som black permatex is in order.
To me it looks like a new fender liner wich is cut from below and from the side, so the machine in the factory still can acces it. And they used a single screw below to close it.
On the F150 forums, the spreadsheets have a tab called "Common" where all the "common" things that everybody does is listed.
Not sure why the "common" tab isn't being kept up to date on the 7G spreadsheet. @roket ??
E.g., 2021+ F150 "common" tab includes this:
Livinitup maintains the spreadsheet. all i did was ask him to make it, then post the link
Paul2020
Paul2020
Australia
2024 Mustang GT Atlas Blue
If we can stick to the title of the ‘thread’ please there are plenty of others relating to patching the hole..
Getting us back on track, if we can just note what changes you made / where you made them & any side effects.
Im ok with spreadsheets least will know the modules to check in when doing ‘ simple way’..
Thanks..
72Skiddoo
Down State Illinois
Thanks..
mea culpa😕
DT-GT
I found this video to be useful for me to understand Forscan basics. Not the specifics for our Mustang, but basics for using Forscan. I found it very helpful and afterwards I was able to easily change my continuous gear display in the easy method. I want to stay away from the changing of digital and hexadecimal values and just stick with things like ABLE and DISABLE. Having a spreadsheet listing those for our cars and a comment on what the changes do would be very helpful.
So you can select enable for gear display without changing values then?
DT-GT
Yes. In the IPC module it showed the name and DISABLED. I simply clicked on it and changed to ENABLED. Now I have continuous gear display.
Thanks guys. You didn't have any issues or errors afterward?
