Factory Oil Slightly Low?
So0_NaSTy
NY
2024 Ford Mustang GT Premium
I haven’t looked for one. I just use the digital number readout on the center stack that has the cylinder temp oil psi oil temp etc.
Yeah. On the screen in front of the driver you should have gauges. If not, go on center stack, instrument cluster and enable it under screens. You should get a literal reading of almost all temps.
Grabber1
Washington
The technician system ford tech’s use. It’s used to pretty much do anything, like looking at workshops for your car, etc. It shows info like capacities specific to your exact car. And it told the tech 9.5 is the spec
Ford has a master tracking program called OASIS.
S650 Mustang Factory Oil Slightly Low? Screenshot_20241219_202413_Google
So0_NaSTy
NY
They do, but that’s not exactly what I’m referring to. OASIS shows active TSB’s for example. However I don’t believe it’s used for capacities and specifications. That’s more their PTS system.
TheGrabberBlueGT2024
2018 mustang gt
Yeah that’s what I use. I don’t know what is the official “warmed up temp” I just assumed over 200 I’m good to go but I could be completely wrong.
2018 mustang gt
I wonder if it’s worth calling my local ford dealer to have them put in my vin and see what it says for oil specs.
Grabber1
Washington
Next time at my local Ford Parts counter I will ask.
So0_NaSTy
NY
When your coolant and cylinder head temps stabilize. Drive calm, once your coolant hits middle of the gauge, your oil is give or take good
2018 mustang gt
I’m gonna have to find these gauges you speak of. All I have seen is numbers.
So0_NaSTy
NY
It’s not in the gauges per se. When the car is on, all the way to the left, opposite of the gas gauge, that’s coolant temp. In the dead center between cold and hot, that’s operating temp.
2018 mustang gt
Oh yeah that one. Yeah I haven’t really gone off of that one much. I normally wait till I hit 200 then I feel safe to go over 3k-3.5k
So0_NaSTy
NY
Yeah I go off that because that is what everything kinda follows. When that’s at temp, naturally oil is there with it.
