Factory Oil Slightly Low?
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
Have heard other people talk about the build up at the bottom of the pan with those valves
never figured out what's so hard about removing a single bolt...
you said it’s hard to remove a bolt? It’s called no mess. You drain into a container via a clear tube. Boom oil drained. Then remove the plug if you want and there is nothing but a few drops remaining.
what about the filter
the drain plug isn't exactly messy
highvoltage
NorCal to SoCal
What about the filter?
When you initially pull the plug oil doesn’t exactly flow pretty. And you have to drain into a pan. I drain into a container and take it right to recycle. No transferring used oil
Never had an issue removing the plug and not making a mess. Usually using a big pan that has the raised section that holds the filter, while it drains, when you remove the filter it makes a mess (you can do the thing where you use a plastic bag...), but again those large pans have enough space to catch that... and it has a pour spout to fill the jugs you just used to fill the car back up...
nothing wrong with the drain valve I just wonder how big a mess people are making without it
highvoltage
NorCal to SoCal
Nobody is making a mess. It’s just easier and faster.
