nitepjony
- Joined
- Sep 2, 2025
- Threads
- 2
- Messages
- 38
- Reaction score
- 68
- Location
- Los Angeles, California
- Vehicle(s)
- 2024 Mustang GT Premium 401A
- Thread starter
- #16
Update: I got it in! After 5 (painful) hours of work I got the cooler in place. While it definitely is possible, it is a huge PITA. Here are some things to keep in mind:
1. If possible, do this on the lift, 90% of the work will be done under the car
2. For easier work, you will have to remove one of the undertrays.
3. When removing the old line, the side held in by the retaining clip will need to be removed with the nut in the transmission, this nut is connected to the piping, you will need to use a socket and hammer to disconnect the pipe from the nut, and hammer the nut onto the new pipe.
4. To access the HB2 bolts holding the other side of the line, the O2 sensor connected to the Catalytic converter will have to be removed, use a 22mm wrench.
5. To get the lines in place, you will need to use a wrench to remove the pipe from the thermostat, and install the cooler lines in 3 pieces (remember which line goes where on the thermostat)
6. You will need to move around the starter lines to get the brackets to fit onto the engine mount studs. (I was only able to get one bolt on, but the lines felt sturdy enough so I didn't put the 2nd bolt)
7. There isn't that much spillage, but you will spill a few ounces of ATF.
While possible, unless you really want to do it, I wouldn't recommend it. This install was a huge hassle. I got to drive my car around and did notice the temps did get lower, however I didn't push the car too far, will do further testing and update the doc with the rest of the instructions.
